0 Members and 57 Guests are viewing this topic.
AlienGrey
Quote from: Hoppy on October 28, 2015, 04:38:26 PM
Poor quality videos and insufficient detail on build and power supplies, no schematic etc to replicate and determine what exactly is going on.
It's the SR193 you can find data on it on the net only look. I keep telling you all you need the magic frequency or apparently is doesn't work.look up the god frequency it's a resonant frequency in it's own right. But you wont bother !
Jeg
Quote from: T-1000 on October 28, 2015, 06:33:14 PM
All you need is the grenade coil and induction heater part from akula/Ruslan circuit and the flyback transformer with its driver charging small capacitance then discharging to coax cable over spark gap. If that is still too complicated I do not know how I can help you.
I wish it could be that simple. I have done this in many ways and every time the output is the sum of both low and high frequency powers. Nothing extra.
May i ask something to everyone. Ruslan speaks about spring effect. This is when two magnetic fields oppose the one against the other. For this to happen i believe it needs a ground in the middle of the grenade. More specifically between second and third layer. So, have you guys noticed any "weird" cables coming out of the pipe in any of Ruslan's devices? At any of Urfa's videos? We look for an extra single cable. Have you?
Hoppy
Quote from: Ed morbus on October 29, 2015, 04:12:28 AM
watch
https://www.youtube.com/watch?v=N4A9xECvsC8
Dynatron-Sergei
http://tarielkapanadze.ru/practice-eng.htm
Given that Captain loz correctly acknowledged that his meter reading was not to be relied on, did he post an update video showing proper scoped load current and voltage measurements, so that he could make a reasonably accurate calculation of power in v power out?
Hoppy
If you expect high standards it should come from institutes and academies but not from amateurs.
What I expect is that these badly presented videos are not pushed as some sort of proof that something special is being demonstrated, especially from guys as technically competent as you appear to be. It proves nothing that when a coax single turn winding is pushed into a coil, that the push pull generator current current drops when we have no idea what is going on at the high frequency generator part of the setup, or with the voltage supply to the push-pull. Even amateurs should learn how to do better presentations than this before they launch them into the public domain.
