0 Members and 86 Guests are viewing this topic.
verpies
Quote from: NickZ on April 28, 2013, 04:32:05 PM
I feel that the secret is not in the low voltage part of the pulse circuit, but in the way that the coils are related to one another.
Yes, there is noting unconventional about the pulse generating circuit.
If there is a secret, then you must also consider that it might be in the way that the coils are related to that metal tube.
NickZ
  Yes, I'm looking for an aluminum tube to cut to size now, as I don't have any copper ones of that size. I'll probably use the shown 7 inch Exciter coil as the akula secondary (big air core), and place an inner ferrite coil in that, which  already has 63 winds of about 20 gauge on it, both pictured previously, along with an aluminum tube. And also wind the secondary coil on the outside of the Exciter coil, for now, without removing the existing winds of 28 gauge mag wire that is now on it. Just wind insulated house wire on top of it, for now, to start with, and take it from there.
I'll use the yoke for only the primary coil form, but with a center tap, and 10 winds on each side of center.  Something like that, any way.
  Even if I only get 20 to 100 watts at first as an output I'll be a happy camper. I can already light an incandescent 60 watt bulb to about 60% or so as is, with just a single transistor and 5" ferrite rod coil, LS Joule Ringer 3.0 ver. style, using only 12v, 500 mA.
  NickZ
anandml
Akku or dally device replication details present in this image. please anyone translate this image it maybe helpful for all..... I got this file from TUNGUS-TK video. I think now this file is removed by author from the video part
NickZ
 I ran into this video today dealing with the hows and whys of free energy. As it reminded me of my father speaking, I had to watch it.  You may get something out of it also.
  It clearly states what T-1000 has been mentioning, in his last few posts.
   This video is easy to understand and listen to as well. He has part 2 and part 3 also, which I also recommend watching, if you are interested. This is what we are trying to do, but, hopefully now with even better results.
  http://www.youtube.com/watch?v=JrDMT6lSeEo
  NickZ
Hoppy
I have attached a photo of the coil / spark gap, transformers and transistors / heat sinks I will be connecting up for my Chibinidze device replication.
The coils L2 & L3 are wound with 14/0.3mm PVC insulated conductors with an overall diameter of 2.66mm. The coil former is 240mm long and 36mm diameter. The slotted aluminium tube is 25mm diameter and enclosed in a thin walled cardboard tube to snugly fit inside the 36mm plastic pipe. Copper tube for L1 is 8mm microbore central heating pipe.
The flyback transformer has a primary winding of 16 turns of 1.2mm ECW. the centre tap has not yet been connected. Note that the tap is not in the centre of the windings in the video.
The multi-tapped mains transformer is of the same build as in the video but a little larger.
I will attempt to construct the device in the same manner as the original, including the straggly twisted wires to the transistors!
Important information still needed: Details for winding the air cored choke L4, the value of C3 and the primary winding voltage on T1.
