0 Members and 627 Guests are viewing this topic.
itsu
Quote from: AlienGrey on November 03, 2015, 08:14:14 PM
Now that is interesting, a PLL is just phase lock, and frequency off the PLL just tries to pull in with the VFO, so if you put a divider in series it will double the lock frequency, you need an AVC control circuit like an LM393 to track for maximum frequency (VFO)     against amplitude feed back circuit, hmm no one else has reported this problem yet. Any way nice video.
AG
Thanks,        Hmmmm,   well  probably no one else build this circuit then.
Itsu
itsu
Quote from: Jeg on November 04, 2015, 04:58:46 AM
Nice work Itsu!
I just wonder why i can't reach the same voltage as your inductor/wima caps when in resonance. I see that you reach voltages up to some 700V while i can not exceed 300V. I use 24V pwr supply, 2XIRFP250 mosfets, 2Χ12T primaries and 25+25T inductor. I will try again today as i find it real weird. In the meanwhile, when i start my heater circuit (yoke-mosfet driver) a strange sound is emitted from my yoke. It is a hissing sound like which also gives anomalous behaviour when i adjust my frequency or pwm.!
Jeg,
what is your output of the MOSFET's?     Mine are outputting at the moment something like 70V squareish wave like  ;D
My inductor coil is 11m long wire in 2 layers each 23 turns bifilar, so one layer say clockwise, then at the end back to the beginning, then again next layer clockwise.
The hissing sound points for me to a short or flashovers in a coil, but with only 3, 12 and 26 turns primaries / secondaries that sounds indeed strange.
Did you perhaps left the yoke old windings on there?
Regards Itsu
Jeg
Quote from: itsu on November 04, 2015, 05:20:22 AM
Jeg,
Regards Itsu
Hi Itsu. Thanks for the help. I will measure my primaries asap and I'll report. My inductor is 12.5m which is the 1/3 of my 37.5m grenade.
About hissing, do you think that it matters if my28T is on the air? I mean it is not connected yet. I have wind it but it is still disconnected. Only the 3T is on place and measures are taken like that.
verpies
I think he is saying that this circuit does not have a detector for detecting the series LCR resonance when driven by a voltage source (yoke's secondary).
Tomtech29
Hi.
Itsu
Thanks for the changes but I thought that at the outbreak of HV. across the wima caps (in resonance) draw the energies Ruslan says that shifts the phase current?
you tuned the kacher to run (pulsed) on a third of that 2.65Mhz = 883Khz with you I do not see a flash- 0.5V voltage increase with or without the kacher ontop
Now let me ask you a question, have you tried using the small transformer to measure the current with a resistor ,so that the peak voltage of it was ripped from the driver pulse Kacher?
-because you did not show where you got 15 kHz input to the controller Kacher or you connected in parallel a gateway one channel Pusch-pull am I right?
or even simply where the mustache at the top of the sine
I wonder if this is possible:
https://www.youtube.com/watch?v=HZ5ZY3L1O9s
This material does not prove anything but there is a visible flare if this is true?
info:
It uses a 200 watt light bulb under the push-pull 25 volts 2.5 amps -At the inclusion HV ampere consumption of the battery
increases to 3 Amper.
The pulse is powered by a 50 Volt draws 1 Ampere.
as instability pulses fall in a different place
https://www.youtube.com/watch?v=QmsZEGyJfBQ
Hmm.
