0 Members and 647 Guests are viewing this topic.
itsu
Quote from: verpies on November 04, 2015, 04:32:40 PM
I think there is an attempt at one, but it's pretty hairy.
For example the voltage is sensed at the primary and the current at the secondary of Tr2.  I'd sense both at the same point in the circuit for stability.
The VCO's output (pin 4) is low pass filtered by an adjustable RC filter at a faint attempt of phase adjustment, arrggghh...
I just would do it differently...
Thanks,  that's what i needed to know.
By the way, i did/do not notice the voltage sensing on the primary, only the "current" sensing via Tr1.
Itsu
NickZ
  Itsu:
  Thanks, for the last video.
  The geese are playing hard to get this winter.
  Seam like the more I tune, the farther I get from the actual sweet spots.  I think that the blind approach is what I may try next.
AlienGrey
Just thought i would post this device from Ruslan before he takes it offt.
https://www.youtube.com/watch?v=fNTYqc28Hdk
AG
Tomtech29
Quote from: itsu on November 04, 2015, 04:34:27 PM
I removed some of the Wima caps and added others to reach the 26.5KHz resonance frequency required to get to the 1:100 relationship with the Grenade resonance (2.65MHz)
The series cap now consists of 2x 0.15 and 1x 0.1 uF caps in parallel totaling 0.4uF.
The kacher was set to a 3th of the grenades resonance being 883Khz.
So basically the key requirements are set and now tuning can start.
Tuning of the fire position of kacher compared to the top or bottom peak of the inductor voltage or current (90° earlier).
Tuning for the max resonance of the inductor, or for the max. output on the grenade which are at different points or somewhere inbetween.
Tuning of the kacher resonance to see if there are any hotspots which increase the inductor and/or grenade output.
etc.
Video here: https://www.youtube.com/watch?v=1Tgkg1XrDlk&feature=youtu.be
Regards Itsu
well what you are at the point now resonant inductor leave / and now the next step is to take a 28 with a slight resonance When choosing a small capacitance 0,15nF so as to lower the resonant frequency peak 28  the winding yoke !
And place on wire serial output 28 which connects with a grenade strong two rectifier diodes !
-the cathode to the circumferential direction of the winding of the yoke 28 is not neutral current which is grounded
Tomtech29
