0 Members and 257 Guests are viewing this topic.
verpies
verpies
Quote from: itsu on November 04, 2015, 04:48:34 PM
By the way, i did/do not notice the voltage sensing on the primary, only the "current" sensing via Tr1.
It's the signal path between pin 4 and pin 3 of the 4046 PLL chip.
itsu
Quote from: Tomtech29 on November 04, 2015, 07:59:23 PM
well what you are at the point now resonant inductor leave / and now the next step is to take a 28 with a slight resonance When choosing a small capacitance 0,15nF so as to lower the resonant frequency peak 28  the winding yoke !
And place on wire serial output 28 which connects with a grenade strong two rectifier diodes !
-the cathode to the circumferential direction of the winding of the yoke 28 is not neutral current which is grounded
TT29,
i did some tests with a 0.15uF cap across the 28 turn secondary and it did increase the output of the grenade / bulbs
Adding a similar cap in series with the grenade (the other C** in the latest ALLEGGA diagram) decreases the grenades output, so another tuning component....
Itsu
itsu
Quote from: verpies on November 05, 2015, 01:16:14 AM
Bad link
Ok, here is a link to one on this forum:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg463785/#msg463785
But i guess you found one as seen by your post after the above one.
Thanks for that post info.
Itsu
Jeg
Quote from: itsu on November 04, 2015, 04:34:27 PM
I removed some of the Wima caps and added others to reach the 26.5KHz resonance frequency required to get to the 1:100 relationship with the Grenade resonance (2.65MHz)
The series cap now consists of 2x 0.15 and 1x 0.1 uF caps in parallel totaling 0.4uF.
The kacher was set to a 3th of the grenades resonance being 883Khz.
So basically the key requirements are set and now tuning can start.
Tuning of the fire position of kacher compared to the top or bottom peak of the inductor voltage or current (90° earlier).
Tuning for the max resonance of the inductor, or for the max. output on the grenade which are at different points or somewhere inbetween.
Tuning of the kacher resonance to see if there are any hotspots which increase the inductor and/or grenade output.
etc.
Video here: https://www.youtube.com/watch?v=1Tgkg1XrDlk&feature=youtu.be
Regards Itsu
Great job Itsu for one more time! You really do what is possible to do and we still see that there is no impact at the output. I don't believe any more that it is just the tuning that makes the difference..
AlienGrey.
I really liked your idea about rectifying so to track the current. It is worth of experimenting.
Also thanks for the new Ruslan's video. It really looks so simple that makes me mad!!! :D
