0 Members and 1091 Guests are viewing this topic.
Tomtech29
Quote from: itsu on November 05, 2015, 04:13:27 AM
TT29,
i did some tests with a 0.15uF cap across the 28 turn secondary and it did increase the output of the grenade / bulbs
Adding a similar cap in series with the grenade (the other C** in the latest ALLEGGA diagram) decreases the grenades output, so another tuning component....
Itsu
I guess say that by choosing this capacitor has an impact on standing waves in the coil grenade!
also it says that only one half of the sine wave pulses put out of Kacher it would be OK.
-the question is what happens to the output voltage ?
I This really does not know whether he is so that 28 inverts the phase ...This arises as a standing wave in this case, what conditions must be met?
https://www.youtube.com/watch?v=I5dovzazXnI
NickZ
  You'll also notice on this last diagram that there is no connection (no jumper wire) between the two induction circuits, and to earth ground. And also, the earth ground on the schematic is only 18m, instead of the original recommended 37.5m,  now 40meters, like Ruslan's grenade, with 2.5 meters of additional wire turns added. Probably to enable him to kick into an better resonant point.
I guess....
  I found no benefit in the two diodes (12R06) placed in series or parallel. Going on way or the other. What are they there for? Heaters? When placed before the bulbs?
  Ruslan has also changed the placement of the 0.15uf tuning cap(s).  Now it's in series, instead of parallel, like it was before. And  with one side to of this cap going to earth ground. And there is now NO earth ground in the induction coil circuit.
  So, which diagram or schematic do we choose go with? As any wrongly placed component, or of the wrong value, or any coil having the wrong number of wire turns, and,  no cigar.
Tomtech29
Hi.
I have no such knowledge on the subject but I guess: to receive a standing wave conditions must be met two of the same frequency waves in two opposite directions!(LC tank alternating magnetic field) He grounded to give it direction "Both ends of the wave to be permanently" and by the end of the second coil I suppose that is.
-not quite catch how Kacher reverses the magnetic field?
My thoughts are guided by the words of Ruslan that he has to work as a spring-it is important to ground the unit performs the functions of both fixed koncy wave.
https://upload.wikimedia.org/wikipedia/commons/7/7d/Standing_wave_2.gif
I learned so much that there must be a node
Tomtech29
This what I wanted to pay special attention to the direction of the magnetic field (but I have no idea how to look at it)causing the opposite direction?
-or else where the signal comes from?
John.K1
Guys, I recall to study what Ruslan says in one of his last videos.  The principal of work of his device can't be better explained (theoretically  :) ) .   https://www.youtube.com/watch?v=OtZHUFSCKlU
