0 Members and 648 Guests are viewing this topic.
Ed morbus
you welcome
I wait for your next video
Tomtech29
Quote from: John.K1 on November 09, 2015, 08:41:09 AM
Hi Tomtech, If I good understand, he says - Do not search for frequency of ground.It would than corresponded to your Tesla and you will loose the support from which Tesla gives impact.  You shortening the spring effect.   ...... or something like that.
In other words , ground has to be solid support- not a part of the wire.
Hi John.K1So something is stuff I keep hearing something about that I Current  is at the bottom of the Tesla coil and the earth wire is a part of the wavelength I hope that something will reveal the entire process of how it arises and tuning step! very confidently mentions this thick lines/does it matter to the amount of mass neutron circuit?
must be a catch somewhere do not and maybe I've been making it up?
I would be happy if reveals what happens with this spring, empty words-Now his lab was created and how to make the PCB blah blah.
good without unnecessary texts'm here without reception :D
Tomtech29
GeoFusion
-We discussed the issue Karcher when the system is powered from the network cable from your home where you have grounded 230 volt, 50 Hz. When you are using a switching power supply. Ruslan talked about the undesired effect
However, it recommends using the battery! (I already spent a "little time" how to create a theme) This widaje eyes were writing not so easy but I salute newer enthusiasts :D
most try your hand.
with your theory may be inferred that the ground wire is only part of the guide and its length does not matter what you wanted to suggest?
I would be surprised that you can simplify?
John.K1
Tomtech- I don't know. In so called Akula/Ruslan evice  -   Akula:  Find the frequency of grounded coil     Ruslan: Do not border finding frequency of the earth  Ruslan on interwiev:  do not use signal generator to run Tesla, use kacher .      Ruslan today:  use SG instead of Kacher    Ruslan before:   Here is how to wind the coil - very important   Ruslan today:  forget what I told you and wind it as standard transformer.
:D
AlienGrey
Tomtech29 and John.k1 i keep saying this over and over again the universe is about musical frequency that are in tune if your not in tune with the 'light' forget it it has to be a multiple of that frequency and not just 8 hz or 4 hz if you look on you tube at resonant frequency you will find multiple of the 8 hz that are natural resonance, they are the ones that draw pictures in the sand, it's not a generator you need its a lock on the resonance of the UNIVERSE music be in tune with the light as apposed to the dark side or get nothing. It's nothing to do with religion you can forget that tangent. every thing has a resonant frequency, everything in the universe, make use of it.
