0 Members and 557 Guests are viewing this topic.
T-1000
Quote from: itsu on November 12, 2015, 10:43:42 AM
i tried my nano-pulser instead of the kacher before, and was using the antenna but without being able to generate a big enough pulse on the inductor/grenade
(nano-pulse used was 1.4KV).
Hi itsu,
Watch what happen when you force driving square pulse length from the quarter wave which is giving free oscillation to half-wave(14:10): https://youtu.be/VGuw3QvoseI?t=10m54s
I think it is close to the truth about the Tesla coil used in forced pulse mode with half-wave square signal as both akula and Ruslan made comments on that video about this matter. And the nanosecond pulse generator is making same pulse on the coax cable in Dally circuit.
When doing so you force the top load to charge on top of grenade like capacitor.
If you will test this, the resulting video would be nice so we can continue discussion.
P.S> It also makes sense to have HF filter between Tesla coil and top load in that mode.
Cheers!
AlienGrey
Quote from: T-1000 on November 12, 2015, 02:00:50 PM
Hi itsu,
Cheers!
Have a look around this area but it will need translating, i have done pages of it already, you need google chrome for that, i cant put it on here its copy right.
Also Eric Dolard says with shorted coax  all sorts of predetermined  things happen like huge amounts of energy piling up 90 deg out of phase with all sorts of things happening, you need to find it and read it, a lot of his stuff is tied down though ! Note the coax length will be important and make sure it's 50 ohm and not 75 ohm or any thing else.
http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=18
PS KT907 is one of a kind, in the west we apear to have a black hole between 1a 1 Watt and high power where the market suddenly changed to SMD some of the FZT853 (RS do them) series transistors fill that gap but have no feed through wires or heat sink tab as HF tends to create a lot of heat dissipated not sure how much but i will find out.
AG
T-1000
Quote from: AlienGrey on November 12, 2015, 06:57:31 PM
You can always use google translate page - https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.realstrannik.ru%2Fforum%2F39-kapanadze%2F134930-ustanovka-ruslana-kulabuxova.html%3Fstart%3D18&edit-text=
And I know this forum quite well.
P.S> In regards to Eric Dollard, he have quite knowledge about longitudinal waves from N. Tesla life research and not much people are really utilizing that. The power is there... As simple analogy - the photons from the Sun are moving in longitudinal waves vector, not transverse(hertzian) and we receive heat/light/etc. ;)
T-1000
New demo videos from Ruslan:
https://www.youtube.com/watch?v=v1zjkc5dYZU
https://www.youtube.com/watch?v=X-P0XPbtsnE
https://www.youtube.com/watch?v=OwKe6jkTY3o
This is mix between Dally and Kapanadze implementation and is utilizing nanosecond pulses with Belkin http://cds.cern.ch/record/607342/files/sis-2003-129.pdf (Russian) generator instead of using Tesla coil.
Jeg
Hi Itsu.  :)
Last night I had some time and watch almost all of your pll series videos. I really liked the way your katcher gets synchronized. The 47nf cap also made the difference. Now are you taking the signal for the sync board between your tl494 and your mosfets drivers? How did you connect the switch that moves your katcher pulse to the positive or to the negative side of the sinus? Do you still use this 74hc14 after the TL 494? Or you just connect the switch between the two driving output pulses from 494?
Hi T1000 :)
I think that the real challenge would be to make grenade vibrating at each full length frequency. When I test it with my high frequency signal generator, I see that at these frequencies between 7.5-8MHz, grenade gives many times more voltage output than at the lower harmonics. Don't you think that the use of a simple transistor i.e 2n3055 oscillator with a main coil and a feed back coil wrapped straight on the grenade would have better results? With an osc. like that we can reach those frequencies with some trimming over oscillator's coil's. https://www.youtube.com/watch?v=9XinprHC4sw  Just a thought
