0 Members and 554 Guests are viewing this topic.
Jeg
Quote from: T-1000 on November 13, 2015, 04:58:51 PM
The transformer in the video had bucking coils in the primary and secondary - https://i.ytimg.com/vi/4Ucgue7eH_4/maxresdefault.jpg
on the transformer E core. The secondary coil had capacitor attached for freewheeling LC.
Hi T1000
I am not sure if bucking coils are the answer behind the principal theory, as Dally uses one way direction coils in his setup and though it works.
Hi Void. Nice to read you again.  :)
Jeg
Itsu :)
Inside the blue box at Allegan's circuit, I see that he is inputting to his mosfet driver a 5V pulse from 74hc132 while he is supplying his driver with 12V. Does this work right? I had experienced in the past a high temperature increase on the driver part due to difference between the driving voltage and its power supply voltage. Is that true or you don't experience any problem driving it this way?
Tnks
magpwr
hi T-1000 and everyone,
Base on the the latest Ruslan video.I have attached to explain the Ruslan latest circuit.If it make any sense to some of you.
I only wish Ruslan is able to do a demonstration on a concrete ground like Akula did with just one thick wire to Earth only  then i will be 100% convinced with no lingering doubts  hovering in my mind.
The part i am lost when i noticed there is no toroid to be found connected to the center tap of the yoke where 2 winding meets.It seems to be connected to the main coil.
That's all from me base on the latest finding.
I am just busy with my latest prototype.I have recently completed designing my largest PCB board to date which contains around "140 components" on one large PCB board.
Basically it's a Variable HV DC generator 170volts to 1560volts which is controlled by just one programmed 8pin SOIC Microchip (Hard coded dual output PWM generator and voltage reference)
and a 7KV SIC Mosfet isolated 28volts pulse provided by one embedded nanosecond generator around 220khz around 60ns....80ns.
Capacitor is a 800volts rated 60uf 3mOhms Ultra low ESR in series.
Full bridge rectifier consist of 4 x 3.3KV 300mA SIC diode.
Why Microchip instead of Arduino simply because it takes less space on my pcb board and to simplify pcb designing. :D
Jeg
Quote from: magpwr on November 14, 2015, 08:16:46 AM
Hi mgpwr. Long time to see you also. I see much and nice work over there. Well done.
Where is your attached explanation? Do you mean the board images?
Tnks
