0 Members and 81 Guests are viewing this topic.
Hoppy
Attached is a photo of the complete build. As expected, there is not a glimmer of light from my 40W lamp I've tried many cap values in place of the 0.5uF and spark gap distances to no avail. The oscillator, flyback and spark gap are working fine at an oscillator frequency of around 64KHz. My transistor base resistors are 2K2 and spark gap cap is 550pF. Transistors are MJE13005.
I'm going to try the 'X' wire next - wish me luck  :)
T-1000
Quote from: Hoppy on April 30, 2013, 07:01:32 AM
What is your choke wire length?
The resonant frequency wave length of it is ~ by wire length * 0.7, the current coils total length should be 4 times less with 4 times wider wire for quick resonant condition(resonance in series on same transformer with standing wave)...
Also to understand effect the following circuit needs to be studed closely: http://imgbin.org/index.php?page=image&id=13184 - C1L1 resonance in paralel, L2C2L3 resonance in series, L2L3 wire lenth ratio 4:1 , everything on single air core transformer. ;)
dllabarre
Hoppy
What did you wind the choke wire on?  ferrite rod?
DonL
dllabarre
Quote from: T-1000 on April 30, 2013, 08:25:14 AM
T-1000
Do you mean the total length of both 80 turn coils added together?
DonL
Hoppy
Thanks T1000. However, I'm sure that there is not enough power from the flyback for the performance shown in the video, even with a tuned setup. As you probably have more experience in tuning than me and as this circuit is an easy build, give this setup a go yourself and see if you can light the lamp as in the video without an 'X' wire.  It does work better with L2 reverse connected in relation to L3, when I can at least see some ringing spikes on T1 primary, although again no flicker on the lamp.
