0 Members and 2451 Guests are viewing this topic.
itsu
Quote from: T-1000 on November 13, 2015, 04:03:04 AM
New demo videos from Ruslan:
https://www.youtube.com/watch?v=v1zjkc5dYZU
https://www.youtube.com/watch?v=X-P0XPbtsnE
https://www.youtube.com/watch?v=OwKe6jkTY3o
This is mix between Dally and Kapanadze implementation and is utilizing nanosecond pulses with Belkin http://cds.cern.ch/record/607342/files/sis-2003-129.pdf (Russian) generator instead of using Tesla coil.
T-1000,
i would like to get rid of this Tesla coil / Kacher as it is causing all kind of damage when not being very carefull.
What is the grenade setup with this nano-pulse circuit?
Is it the same setup, so a grenade (3 layers) and a bifilar inductor at the grenade's lower end with the change of a
shorted coax cable wrapped around the inductor/lower grenade instead of the kacher / antenna?
Or do i understand that there is also a new (resonance) coil as first layer underneath the grenade (red tape in the video)?
If so, how many turns (looks like a tesla like coil like in Dally's setup) and with what kind of wire and how is it connected?
Thanks,  Itsu
starcruiser
Quote from: Jeg on November 17, 2015, 04:47:09 AM
Well done DA, thanks for sharing.
Looks like DA is using the high frequency mosfets ringing for firing his grenade. Also, this black box connected in parallel with the bulb.. do you know what it is? Looks like a 12V dc car regulator.
These 6 transistors as starcruiser called them, most probably are diodes.
DA1, is it possible to show us which circuit of Ruslan do you use?
Thanks
Well they could be diodes, but I see 3 legs thus my assumption they are FETs of some sort. the black box looks to be a capacitor
Regards,
Carl
DA1
HI  Jeg   black box= C 10UF/400V AC
สวัสดี  jeg  กล่องสีดำมันคือ  = c 10UF/400V AC
T-1000
Quote from: itsu on November 17, 2015, 08:02:20 AM
T-1000,
Thanks,  Itsu
Hi itsu,
The coil winding specs for latest Ruslan demo device are not known. I would not go into speculation on how it is made but there are other things you might try.  Here is my personal opinion about this stuff:
From the old Kapanadze device memories shown in Wesley video back in 2011 - the coax cable have to be like tuned antenna and deliver disrupting signal between transformer primary and secondary coils. Which mean the signal should be strong enough for interference there and the magnetic coupling between two coils should be not too strong.
Also same thing apply to Tesla coil which is being used as step-up transformer with top load capacitance which is coupling with grenade coil.  If you cannot get much difference when it is on/off, the same conditions are missed out most likely.
P.S> The https://www.youtube.com/watch?v=Zul6Q4vDG7E also is showing symptoms of the effect I am talking about.
Cheers!
itsu
Quote from: T-1000 on November 17, 2015, 10:12:50 AM
Hi itsu,
Cheers!
Thanks T,
i thought that Ruslan  was explaining in the video how he made the new grenade.
ok,  never mind, i kind of get what you are telling, the problem is with turning this into something that has the correct effect.
Itsu
