0 Members and 824 Guests are viewing this topic.
itsu
Jeg,
i don't think a 12.5pF / 1Mohm probe has any influence on a 26KHz resonance signal, well at least it should not.
I will take a look at it, but the coil in that video is an old one and not in use anymore (solid copper wire).
Itsu
Jeg
Itsu.
You are right on the fact that by placing your probe in parallel with your inductor, the 26KHz resonance is not affected. This is because inductor is in series with the line which vibrates at 26KHz. But.
  If you place also a parallel to the inductor capacitor, then an other one tank circuit is being formed. This new tank, oscillates inductor to a second frequency the same time. If your probe's capacity is too small, then you probably tune higher than the frequency that your nanosecond pulser is trying to induce.
itsu
Oops, another reason to avoid Kachers in your direct environment i guess:
https://www.youtube.com/watch?v=tmFXsMU_myw
Itsu
AlienGrey
Quote from: itsu on November 29, 2015, 08:34:17 AM
Itsu
That's why ot's important to select a a good frequency, Eric Dollard  and Tom Brown did some interesting tests on this phenomina and you need to be careful what you are dialing up in frequency.
starcruiser
Itsu
That looks more like the water in the plant is attracted to the coil
Regards,
Carl
