0 Members and 772 Guests are viewing this topic.
NickZ
   Itsu:
  Thanks for the pics,  that driver circuit looks really nice. I'll be waiting for your results.
   You mentioned: "So we might need to loosen up that coupling so that the kacher / nano pulses are able to disrupt the signals causing the effect to happen."
   "Loosen up that coupling"?  What do you mean?
    There is something that has me perplexed. When I watched Geo's video showing how his hand can totally disrupt the entire output at the bulbs. That effect makes me wonder WHY the induction circuit can be disrupted in that way, enough to put out the bulbs.  As my circuit does not kill the induction circuit's output, no matter what I do to the Kacher, or where I place my hand.
   Maybe Geo can comment on that.
itsu
Quote from: NickZ on December 04, 2015, 10:58:22 AM
   Itsu:
Well,   like adding something inbetween the inductor and the Grenade, like an air gap (foam) or a sheet of copper (with a slit).
Itsu
Jeg
Hi guys :)
Nick, I have also experienced this. There are frequencies that look hell steady when I approach my hand close to the antenna or to the grenade. Now I have tuned to a frequency that is very sensitive to the same conditions. The difference between both cases is that the first case uses frequencies that don't belong to my grenade's natural harmonic set of frequencies. The second does use one of this set, and looks quite sensitive when adding external capacitance through my body.
I am waiting for components to make allega's sync board (blue box). Hope that next week I ll be ready to make some tests.
Good work itsu. Can't wait for a video using your new nanopulser.
NickZ
     Itsu:
   Loose coupling? I don't know...  Your grenade has been wound to the proper specs.  Mine may be a little off, here and there.
   A controlable TL 494 and PWM board can help to adjust the frequencies for the best waves lengths between the two induction circuits. But, have I personally have not seen much effect at the bulbs, from the addition of Kacher's impulses. Only just a tad, here and there, at times.  I don't know if going any lower than 0.5mhz for the Kacher frequency now will help, or not, as it's running  frequency has been everywhere else. But, I'll need to get more mag wire to go any lower in frequency, which can take a while to get a hold of the right gauge. In the meantime I'm doing what I can to obtain the "effect".
   As always, any ideas are welcome.
forest
that was called "disruptive discharge" , right ?  ;D
