0 Members and 715 Guests are viewing this topic.
magpwr
Quote from: itsu on December 13, 2015, 09:36:08 AM
Magpwr,
thanks for comments, they are allways welcome.
To my understanding, the nano-pulse is being generated by the DSR diode (KD226D), so the MOSFET and its driver are not running at nano second speed.
They run presently (video) on 10Khz repetition frequency generating a 200ns wide pulse, therefor i don't think they are that critical, however we
do need/want a fast/clean on/off switching of the MOSFET.
The present UCC37321 driver should be able to do that, but it might be its to far away from the MOSFET and the socket it is in might have to much stray capacitance.
I will try to modify this by putting this (inverting, so needed for the correct drive pulse polarity) driver on 5V and adding an additional UCC27511 MOSFET driver
directly attached to the MOSFET legs.
I have a 10uF low ESR tantalum across the driver plus/minus leads already to supply for the source and sink currents needed by the MOSFET gate.
Regards itsu
hi itsu,
There is difference in output if you choose 15volts supply for mosfet driver and 23volts to 24volts for IXDI614(inv)/IXDN614(non-inv) mosfet driver to properly turn on mosfet.
My circuit also need around 200ns at the mosfet driver
There is nothing else to add at this moment...
I am considering creating a 6kv high frequency nanosecond generator for own use and not for public.But i am thinking what good can it do for Dally or Akula device.
Although we may know that dally was merely using around 1kv pulse for the coaxial cable which is shorted at the end.
If dally was using coaxial cable which means the outer shield  would need to be connected to the pulse output and the ground from nanosecond generator to the center.
This is to ensure the pulse would "radiate" outwards rather then using the outer shield to suppress the nanosecond pulse.
AlienGrey
Quote from: AlienGrey on December 13, 2015, 04:44:55 AM
Hi yes it's sort of all going, some where.
I recently made a Tl494 driver module as per circuit posted on lists posted here, I first noticed the Pots scan over a very wide band width, a few hertz to a few hundred kHz I altered the 2.2k in series with a 15k and  the 22k pot I had to  jumper with a 4.7k in order to cover the 17khz range, it's Farley stable to a point but can drift 20 or 30 Hrtz, I'm not to happy with this drift as it needs locking to the earth's resonance.
I have made a device that's crystal locked to this frequency that's a simple dial up setting, using a cd4060 a xtal and 3 cd4522 down counters and some cheep BCD switches, that do the job, it needs injecting into the TL494 earth side of the timing cap, instead of going to earth link,  the other thing here is the wave drive switching circuit has to be a square wave not a sine as it's not possible to have harmonics easily with sine wave, so be aware of this as some of the Russian speakers have mentioned this little gem including Wesley.
Also the Nano Pulse, does this pulse have to be set to the peek of the grenade resonance, centre of its sine wave ? ( as this is the most useful part ) so what ever that frequency is set to would determine the nano pulse's repetition rate, would it not ?
https://www.youtube.com/watch?v=_xh8uH9z6vo
magpwr
hi everyone,
I have uploaded "A world first 1.1kv nanosecond generator which powered by just 1 wire via Avramenko plug".
The high voltage source is merely a 1xAAA powered disposable camera circuit.
At the moment i am able to achieve around 46volts via AV plug as required by my nanosecond generator while achieving maximum repetition rate of just 70 to 80hz.
http://www.youtube.com/watch?v=5RKxzs_JI8E
Future version of my nanosecond generator may likely by powered by kacher, tesla coil or my  tesla transponder winding as shown in my previous video.
Final objective to use 1 wire to provide enough power to nanosecond generator while achieving high repetition rate 17khz....37khz using coaxial or Antenna as output.
This experiment is just to provide some ideas for the experienced.
That's it.
Merry Christmas and a Happy New Year.
T-1000
Quote from: NickZ on December 13, 2015, 09:36:26 AM
  Too bad we can't just buy the right driver boards...  from Oleg, or the "Boys"  Maybe it will be possible at some point...
  If only T-1000 would not be too afraid to just ask them.  The worst that can happen is they can say no. But, if they say yes???
I asked Oleg about that few times just he did not show that intention. So you will have to order PCB after designing it yourself unfortunately.
For nanosecond pulse generator - I would not invest too much time in making it perfect unless you already see power amplification effect even a little bit...
lost_bro
Good day All:
Just wanted to attached this excerpt from Tesla's C.S.N.:
Pertaining to the calculation of the 'Ground' cable in a resonant system using an 'Extra' coil (aka- Antenna in Ruslan's system).
Apparently the *length* of the 'Thick Ground cable' is very important as this in part determines the fundamental frequency of the system.
Note where Tesla mentions that the cable was not laid straight, but coiled with a couple of loops and that this also affects the calculations.
take care, peace.
lost_bro
