0 Members and 574 Guests are viewing this topic.
AlienGrey
I think you all need to work your way through all this guys videos starting with this one,  and make some notes, he is the one who started it all !  good luck
https://www.youtube.com/watch?v=Mnoy2D4wuf8
AG
GeoFusion
T-1000
NickZ
    Geo and All:   Happy New Year...
   After re-watching your last video, I have some observations, and some questions.
   First of all I noticed that your halogen bulb works much much better, than the 60w incandescent bulb.
Is that halogen 220v, or 110v?
   You mentioned that the 28 turns, tuning caps, are placed in series, not the normal parallel way.
Why is that? You're not using the 0.15uf wima caps there? Have you tried any HV 0.15uf cap there in parallel?
   Your push-pull is running off of one mosfet? Or is that a voltage regulator on the heatsink.
   Why are you tuning using low wattage bulbs?  That push-pull won't light the 1000v bulbs that you have?
   Why are you not using your Kacher, to heterodyne the frequencies?  Why the extra long Kacher secondary?
As you know, without the Kacher involved, it's just low efficiency inverter, partially lighting some bulbs.
   Any ways, I noticed something unusual when I had first used one of my 3" ferrite yokes for the push pull system, that also had
a previously wound with a full spread of HV voltage windings right over the torroid. Then over that was the normal  primary and secondary yoke coils windings, were wound on top of that first HV windings coil.
   I think that may be an easier way to feed the Kacher's input source,  directly to the Kacher primary coil, from HV windings wound on the yoke.  I got some huge sparks, at times, when there was some kind of shorting going on within the yoke coils.  Big loud bangs, like a capacitor discharge.  Not like the sparkling type sparks. There may be something to all that.
AlienGrey
Quote from: Hoppy on September 09, 2015, 10:04:45 AM
The real secret was out as soon as he did his outdoor video with the earth wire that was not an earth wire, which disappeared down the pipe instead of terminating to it! Who's going to invest on the strength of videos showing LED drivers, batteries or no batteries. Even TK has no takers with a so called self-runner that drives a powerful light bank. The only thing certain and common to these guys is that they will concoct anything to make money, including techinical bulls.... babble.
Perhaps, perhaps not, are you going out their to prove it ? The trick is some one else has already done it infarct three have !
