0 Members and 83 Guests are viewing this topic.
AlienGrey
Quote from: TinselKoala on January 02, 2016, 01:33:46 AM
I'm not making a "claim", I'm pointing out the logical consequences of someone else's claim. It's not up to me to "disprove" a claim, it is up to the claimant to prove that his claim is true.
Yes, I've investigated some of the claims of Don Smith. But like everyone else who has ever tried, I was not able to get anything like "overunity" performance. Since nobody is able to do it, and Don's not around any more, the conclusion must be that he couldn't really do it either, and this conclusion stands until someone proves otherwise.
Ah replications they are fun to watch aren't they just, making high voltage and high frequency and collecting the peeks just won't work, hmm I wonder why that is ? Just like you i have reached the same conclusion, we must be on the same wave length you and i, any way thanks for your thoughts. ;)
Dog-One
Quote from: itsu on January 02, 2016, 05:07:24 AM
Something like what Mikhail is doing here:
https://www.youtube.com/watch?v=_jzNRlmrqwE
The fellow certainly has attention to detail.  I get the feeling from looking under the hood his device isn't yet completed.  For example, the toroid in the center, do you see any wires connected to it?  Must be a WiP (Work in Progress).
itsu
Dog,
correct, its a WiP, see mine and his comments underneath the video.
Itsu
Dog-One
Quote from: itsu on January 02, 2016, 08:12:23 AM
Yes, understood now.
I'm going back to the original Dally coil and driving it strictly with function generators until I can understand how this coil operates.
The theory I'm attempting to prove or disprove is whether according to Don Smith the electron spin can be altered, breaking the mutual inductance between the primary and/or resonator coil and secondary.  So far I have established that I can drive the resonator coil well beyond the input power I'm exciting it with from the primary.  So far so good.  Next I will see how the output winding and the resonating coil is coupled and by way of the coax, attempt to break or unidirectionally break this coupling.  If I can get that far, then I need to figure out how charge separation is augmented via an earth ground.
This device must be using the concept of Spin Connection Resonance as talked about over at OUR.  It's just a matter of figuring out how and implementing a suitable solution.
What I would like to do is have all my windings have an exact one-to-one ratio while still having identical wire lengths.  Physically this seems impossible to do, so I need to find out if there is a geometric way to keep the ratios a multiple or even divisions as Don Smith suggested.
d3x0r
In comments on http://www.liveinternet.ru/users/edward_lee/comments
10.16.2015 1:40 [/size][/i](link)[/size][/i]
I was able to repeat and running! And if nanosekundnik replace a bobbin from the motorcycle (coil)[/size]Make a good outcome, will be 1 kilowatt. We must spank strong discharges. And by the way ! Detachable coil wound bifilyarom better, koaksealny move the cable to the side (no matter what) I recommend to shake the pipe 50mm from the plumbing. The resonance coil shakes 1/2 with respect to the winding supply (in this case Tesla) replaces it with 1mm + resonance. Mota in one direction all. And so the 20 cm !!! Then koakseal. The rest of space is filled with 2.5 mm material removal length of 25-30 meters. We get the 230-255 volt outlet. Green normal transformer lowering. +15 15 outputs TLku generator 110 +110 share. There are two coils of 110 volts. One GNSI on the other nourishes our coil. It is important to remember that the response does the sine current !!! Because going kinetic pushing magnetic field ether. Ether spins torus. From there and gain. This scheme I brought to 500vatt and more. But now I do better!Everything is just important not to be lazy. (Ruslan Kulabuhov)
[/size]
10.16.2015 1:51[/i]
I recommend everyone to do at a frequency of 15kHz or slightly higher.
GNSI change the ring on the yellow and white. The power supply of the computers they have.
[/size]Do not put the pump into the transformer. Place the ferrite from TV (otklanyalka) Mota 3 turns on the resonance coils 48 to supply GNSI. Do not forget that GNSI must operate from the same current as the pump coil. It is important !!! Since the currents in the system are not classical. No other sources GNSI not make. Use powerful import type transistors K2698 or K2611
frequency generator can be GNSI 1/10. Scheme 1 microsecond impulse !!! Not to be confused !!!Someone made ​​a mistake and wrote 1 nsec. This 500 MHz! What's really in this sisteme.Rekomenduyu collect all this miracle than Akulovskuyu garbage. Since I promuchalas 2 years and was unable to stabilize her, and bring to a good condition. (Ruslan Kulabuhov)
(Original)
16-10-2015 01:40 [/i]
Я смог повторить и работает ! А если наносекундник заменить на бобину от мотоцикла (катушка зажигания)
Сделать хорошую развязку , будет 1 киловатт.
Нужно шлёпать сильными разрядами. И кстати ! Съёмная катушка лучше намотать бифиляром , коаксеальный кабель сдвигаем в бок (не важно в какой) Рекомендую мотать на трубу 50мм от сантехники.
Резонансную обмотку мотаем 1/2 по отношению к обмотке питания (в данном случаи Тесла) Заменяем её на 1мм + резонансную . Мотаем в одну сторону всё. И так 20 см !!! Затем коаксеал . Остальное пространство заполняем 2,5 мм съёма длинной 25-30 метров. Получаем на выходе 230-255 вольт. Зелёный трансформатор обычный , понижающий. 15+15 выходы на ТЛку генератор , 110+110 разделяем . Там две катушки по 110 вольт. Одну на ГНСИ , другая питает катушку нашу. Очень важно помнить , что резонанс делает синус тока !!! Потому происходит кинетическое толкание магнитного поля эфиром. Эфир закручивает тор. От туда и прибавка. Эту схему я доводил до 500ватт и более. Но сейчас сделал лучше ! Тут всё просто , главное не лениться. ( Руслан Кулабухов)
16-10-2015 01:51 [/i]
Рекомендую всем сделать на частоте 15кГц или чуть выше.
ГНСИ меняем колечко на жёлтое с белым. В блоках питания от компьютеров они есть. Не надо ставить в накачку трансформатор. Ставьте феррит от телевизора(откланялка) Мотайте 3 витка на резонанс , 48 витков для питания ГНСИ . Не забывайте что ГНСИ должен работать от того же тока что и накачка катушки. Это важно !!! Так как токи в этой системе не классические. Никаких других источников в ГНСИ не вносите. Используйте мощные импортные транзисторы типа К2698 или К2611
Частота генератора ГНСИ может быть 1/10 . На схеме импульс 1 микросекунда !!! Не путайте !!! Кто то ошибся и написал 1 наносек . Это 500 МГц ! Что не реально в этой системе.Рекомендую всем собирать это чудо , нежели Акуловскую фигню. Так как я промучался 2 года и не смог её стабилизировать , а также довести до хорошего состояния.(Руслан Кулабухов)
