0 Members and 103 Guests are viewing this topic.
AlienGrey
Quote from: Dog-One on December 26, 2015, 01:02:52 PM
Yeap, it looks like the real-deal to me.  Thanks for posting it.
I'm really starting to think there is something in the field of electrostatics and magnetics we aren't familiar with or are otherwise ignoring in our builds.  These devices are acquiring a charge from the earth and redistributing it into the closed-circuit.
I went back to an old 1917 Hawkins Electrical Guide and began studying what was known back then.  The one thing that clearly caught my attention is the behavior of a Faraday Cage (or charged sphere) where the charge completely exists on the outside and no charge on the inside.  This got me thinking about the grenade coil as a container of charge.  With a continuously pulsing magnetic field inside the grenade coil, I have to think somehow this is acting like a pump.  The electrostatic charge is pulled into it, then redistributed to the exterior copper windings.  When this happens, the charge can no longer be detected from the inside, but it's there and when sent to the load, has a real effect.  I still can't quite picture in my mind how this happens, but my instincts tell me it's something worthy of more study.  The interesting thing I noticed in the Hawkins book is that this book tells you what is known and only what is known; everything else is up to the engineer to manipulate however they wish.  There's a lot of freedom in that and my feeling is we are assuming certain laws of physics that don't actually exist--basically shooting ourselves in the foot.
Yes! Eric Dollard did a video about this if you cant penetrate a Faraday cage your generating magnet field at 90 deg as well as electricity and we need static off the Katcher, it has to be set up and designed dead right or you wast time and energy, and a Faraday cage is useless with scalar as it uses something called counter space.
https://www.youtube.com/watch?v=Vw46iH-t3ec
Dog-One
Nick is always mentioning off-the-shelf modules.  I found this Class-D audio amplifier that may do the trick:
http://www.classdaudio.com/amplifier-modules/ti-amplifier-modules/ti-600-amplifier.html
You would need a 48 volt universal power supply for sure instead of 24 or 12.  I'm using a Mean Well HEP-600-48.
I suspect with the correct number of turns on the yoke or toroid transformer and a decent sine wave generator, it would drive the Ruslan or Dally circuits just fine.  Then its just a matter of getting the correct synchronized impulses and you're off to the races.
NickZ
    Dog:
   At $185 for a simple audio amp??? I'll wait for you to try it out, first.
   It is not a PWM,  nor does it have frequency controller, nor is it push-pull configuration.  So, it's Not what I'm looking for...
   And it's way, way over priced.
GeoFusion
Hi Guyz,  :)
Want to Point out on something important here to everyone working on the Ruslan / Akula and Dally systems,
We have all what we need as Push pulls and Kacher/Tesla coils and many other impulse circuits ready for use,
but we are missing the most important part within all of this.
What we all need in these systems to function  is something to let it all Synchronize together.
    ~ A Mediator transformer or Mediator circuit connection ~ Synchronization , the bringing of both independent  Volts and amps together and in resonance. Same  Source but 2 or more different circuits. example ( 1000V x 1A = 1000W  simple idea right? )
URFA's Toroid simply does that! :) it works.
I did some measurements yesterday on the input side of the 24V PSU and saw me pulling only 0.4 A / 120V
and lighting 210W of bulbs but 60% brighness, that already shows amplification.
This one is done without kacher connected but Mediator transformer is connected though.
When shorting the end of the two 24AWG wires where I should be connect the Kacher you already see amplification to the bulbs.
Today I will Rig up the entire system and lets see what Chaos it can bring out :).
Cheerz~
ramset
some success with Electrostatic work here ? [it has been intimated this may be a source for these energies here ?]
A very recent thread
http://www.energeticforum.com/renewable-energy/20365-steele-bradens-electrostatic-motor.html
and a prior thread
here http://www.energeticforum.com/renewable-energy/16565-steele-braden-generator-4.html
respectfully
Chet
Thanks Grandma
