0 Members and 596 Guests are viewing this topic.
macitana
AlienGrey
Err Vasmus  an interesting conversation, but is it true  ?
https://www.youtube.com/watch?v=z5EaD7GUgCA
DragonsLord76 2 days ago
+ Vladimir Tag oh, sorry, I forgot that fag Kulabuhov it with a flashlight and began by weight of noodles. How it all works great, easy going and everything. Yes, but not one person even a repeat of his "explanation" could not in five years. Conclusion? The conclusion is simple: fag mishandled it, and be happy that I fakie not publish, and do not force people to spend the money time and effort to all known non-working garbage.
Reply  · 1
T-1000
Hello,
Here is some educational video for understanding what happen between grenade coil and ground - https://www.youtube.com/watch?v=qwVOp-HPIVE
Please note, the electrostatic HV source is the closed circuit there and the step down coil is used as open end between discharge and the ground. All charge exchange(pumping effect) is happening over electrostatic way.
In Kapanadze style devices the HV source is the Tesla coil running in the resonance and the grenade coil used to receive external charges to amplify current.
Cheers!
Tomtech29
Quote from: T-1000 on January 09, 2016, 03:39:26 AM
Hello,
Cheers!
Hello
Thanks to the guy mentioned that just put the two towers and ionize ion sphere laughed it.
for such a big footprint at home?
-such a measure have not yet seen :D
without connecting wires such a meter reading will jump at such a high voltage discharge
I would see something very keen on acquiring amplify current -if the system is grounded is part of the power goes to the ground and making the results of his multiplication?
T-1000
Quote from: Tomtech29 on January 09, 2016, 07:01:18 AM
-such a measure have not yet seen (http://overunity.com/Smileys/default/cheesy.gif)
You can ignore multi-meter readings in the video. It is just indicator of induced voltage over coil there. In fact, usually you won't get any current going from/to the ground in any conventional closed circuit.
The important bit there is how you mix two different currents inside wire in the open system where the closed loop is the part of it. Also there is fundamental thing what makes electric current in the wire and this is where it gets interesting when you inject/attract additional particles into circuit.
