0 Members and 69 Guests are viewing this topic.
NickZ
  "Ruslan-Dally-Accula devices ? Ok but where is one that works (http://overunity.com/Smileys/default/huh.gif)? and why have you not built one (http://overunity.com/Smileys/default/huh.gif) And why do people have a problem building ones that work even if they build them the same as the so called inventor" (http://overunity.com/Smileys/default/huh.gif)
        end quote.
   They ALL WORK, for them. We have tried to replicate some of their devices, but still no cigar, and so we're still working on it.
At least a couple of us.
   You've built a mega watt self running generator???   Sure!  I almost believe you,  but....  not today.
   If you don't have anything more to share, please find another thread to spam. Or better yet, show us what you've built.
   Wesley has already warned you about flooding these threads with your BS.
AlienGrey
Quote from: Tomtech29 on January 09, 2016, 10:48:03 AM
NickZ
Russian / Akula devices faze shadow passes as someone already mentioned progress of 4kW. generator comes to 4W. LED this absurdity even if they showed what a way to make a proper configuration What could anyone understand and execute.
-which is currently only irritate me such presentations if they had to prove that it can not be done because the sea not be free.
Devices can not be reproduced will still be chosen if such a direction that people do not learn ...(I hope that this will change and open the gate and us what we want but I could not)
First thing how you going to find natural spot on resonance frequency with out spectrum analyzer ?
From what i have read, the wound exciter is a 'measured length of cable' 'the wave length', tuned to natural resonance freq' not any old frequency, wound on a tube that's again a harmonic length of the fundamental, and a 1/4 wave collector wound over a 1/4 of the tuned coils physical length, i would think every thing would have to be related.
The experiment !    master coil needs to be exact spacing and in resonance with natural earth resonance with spaces to tune. the secondary needs to be same physical wight of the primary.
If you go back to old Akula Vids (if you can find them) he shows all this. Or your wasting your time.
    |oooooooooooooooooooooooooooooooo|   the wave length of the cable
    | 0000000000000000                                the coil  wound over a 1/4 wave length exactly ( test tuning)
    | 0000                                               slidable 1/4 wave collector coil  1/4 width of wave length (test tuning
NickZ
  Well, some of us are using a signal generator and spectrum analyzer to look for the best highest frequency response.
But, when tuning the device to match this same best strongest frequency point,  nothing happens at the output of the bulbs.
  Some guys are showing a higher output when the circuits are in sync, but not showing any OU, nor self running, as I've mentioned previously. Which is also where most of us that have gotten to that point, are stuck at, presently.
verpies
Quote from: AlienGrey on January 13, 2016, 09:01:26 AM
Is it a series resonance or parallel ?
T-1000
Quote from: NickZ on January 13, 2016, 09:20:13 AM
There is also another part - the current movement between device and earth ground. Which need to be tuned in additional to the frequency mixing and best summary output. Without pumping effect the closed loop circuit do no give more energy on output than was put in. Ruslan, akula and others was talking about amplifying current on the output without additional impact on the input and this is where the earth grounding play its role.
