0 Members and 240 Guests are viewing this topic.
Hoppy
Quote from: NickZ on January 17, 2016, 08:52:47 AM
  The older video was using a different yoke with the windings for 12v, and using 12v battery or a old 10amp battery charger, which is not the same set up that I have now.  So, I can't really replicate the same effect, but, I'll see what I can do. However, I think that what Geo has just shown is the path to free running.
  I've since that video have burned out the 2A wall adapter, and now only have a 12v, 1.6A wall adapter. But, I'm more interested in achieving what Geo has managed to produce, instead.
  I also had better luck with the older set up, as far as seeing some interaction between the Kacher and the induction circuits, than I do now.  Don't know why...
Not to worry Nick. However, if you get that interesting effect on your new setup, you at least now have a scope for measurement / analysis.
N20Wolf
In archive information by generator Ruslan Kulabuhov
https://yadi.sk/d/6MuASmQCmz2Bc
To download, click: "Скачать/Download".
GeoFusion
Hi there :)
   Nickz,
Thank you for you input, :) and try out,
I see you used a frequency analyzer to see the wave pattern, very interesting how it moves :).
I have seen your vids too, nice job man, but where amplification happens within your circuit is only when chaos mode enters
the Yoke. What misses now is to let kacher Raise Brightness and voltage. Pushpull should not raise brightness to that extend.
Try to build a Mediator Transformer Which I also Build,
that will help for the effect. try it out :)
I will draw a schematic soon. and a new vid too.
I still need to measure what I draws to comparison when It  produces, that will come.
For sure almost there for Self looping Nick, But Will wait for other caps to come though. I want more Output.
The Mediator Transformer is not stepping up the Voltage for the Transistor otherwise it
would blow up the transistor one time and it did a when in trail. But lesson learned.
but Mixing is what happends when you connect one side of mediator to + and the other end to the device you desire to connect.
both Kacher and Pushpull.
It will bringing the Pulsed DC form PSU  in the mediator and Both KAcher and pushpull with get same information, Like same freq.
Voltage can be introduced externally and will combine beautifully with the amps ext. and is what makes the beautiful Watts.
Nick try to put a piece of metal in the grenade and tell me if it gets hot for the test.
I'm very sure it would self run this time without battery as how Ruslan does, there is Current movement in the ground :)
In next vid I will show.
     Hoppy,
Yes I remember you telling me about able to reach the effect to certain extend. You should try what I did, it works!
Yes, I think it might be so that one of the mosfets are working,
I think it's the one Pulsing with the NegativePulses on gate is getting hot.  it's wierd. BUt will need to verify this.
will let you know as soon as possible when I disconnect the one I think is not working.
I think I will need to build or order a better PushPull.
Yes The blocking Diode at the PSU is very important, Because I blew Up one when not using Blocking Diode.
Btw For all to know what was making those noices, was coming from the Mediator , To Yoke and some how faintly also inside the PSU.
BUt Heavily from Mediator, the Noice is extreme. especially when hooking up kacher for effect.
Cheerz~
Hoppy
Quote from: GeoFusion on January 17, 2016, 07:33:13 PM
     Hoppy,
Cheerz~
Geo,
I may be wrong but I don't think another / better PWM will help to eliminate the mosfet issue. I would be interested to see what effect disconnecting the large antenna coil (at the junction with the ferrite rod choke) has on the 'effect'. Again I may be wrong but I have a feeling that the increased lamp brightness is as a result of the PWM imbalanced output caused by the Kacher HV on the supply lines but not directly from the Kacher induction into the grenade.
NickZ
     Geo:
    Thanks for your comments.
    What size is the green toroid? Have you tried to use another smaller (2 1/2") yoke for the mediator?  Seams like it would work better than your smaller green choke.  Vasmus uses bigger toroids? Or not.  We need to know just what it's purpose is, and what it's actually doing. It may be restricting your output, as well. Or can you still light your 1000w bulbs, not just a single 100w halogen bulb. Remember your 24v PS is providing the circuit with 15A, and 360w. But, your output is only showing partially lighting 100w bulb.
  The recommended Kacher transistor(s), can handle 250v, 15A.  Without blowing, hopefully.  So, their input voltage can handle much higher voltage than just 24v from the PS, or batteries.
http://www.datasheets360.com/part/detail/2sc5200/5632587128045190261/?se=ggka&setag=d360&cid=paidsearch&gclid=CMai8JSN6sYCFYsWHwodwNANjQ
    My heat issue with the fets was resolved by the addition of the missing 0.68uf tuning cap parallel to the primary yoke coil, as in the RMG crt. As I also had one fet heating more than the other, previous to that.  However, my yoke gets warm now, after installing the mentioned 0.68uf capacitor, but the fets now stay barely warm, like babies milk.
   I can still light several 100w bulbs at a time, though, without a voltage drop.
   Check out the TL 494 board for $8.  Same as Itsu use on his video, and also recommended me to try out for my yoke circuits.
http://www.ebay.com/itm/TL494-KA7500-DC-9V-25V-Driver-Board-DC-DC-Converter-Inverter-Boost-Module-PWM/181449170972?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D29981%26meid%3D30dc72264dca4a97a16b1bc6190c0221%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D141408846492
   Waiting for your next video.... the self runner.
