0 Members and 28 Guests are viewing this topic.
GeoFusion
   Hoppy,
Well :) for me it's only about a small issue with the IR2110 chip also warming up sometimes or the Fet. it's odd..
I will take a look at it and see what I can come up with.
But did some minor changes and suddenly the Fet doesn't really heat up anymore.
I will shortly upload yet another video of the device Resonant Radiant Device where you/ all can see big differences while
I connect at different points for Effect and also where it doesn't work and letting know how important the ground is.
Ok , I will do that as following removing the Tesla coil connection from the Ferrite spring piece connect to  to see noticeable difference in effect :). no problem.
Oh and do not disconnect the system from the ground which is connected to the Grenade..
It's complicated :/
Nick,
The Green toroid (Mediator) is about the same size as Urfa's. 3 salvaged from hug board from boiler heater system from a company where my uncle works.
I can measure it for you later on. I could try other Diameters to see if there is any difference in effect.
In Vasili's case (Vasmus,
That is called a  " Sumator " Has a  Unique  and very different way of working but
has the same way of mixing and getting the effect and at the same time stepping down energy to other circuits and for loop.
I did manage to replicate something similar to that Vasmus Sumator a while ago. but left it aside, There is one on youtube shows how to use it .
the output of tesla coil to convert to usable energy. it works.
But to be clear, Mediator is completely different from what Sumator Does.
The Purpose of The Mediator transformer is to mix both external sources together, to let them work as One unit at output.
It Allows to combine the External Volts and External Amps together, It amplifies what we call Torsion Field to fill up with greater energy.
Imagine this, 1000V x 1A = 1000W, that should be a exmaple :). Is somewhat How I think.
no, It's not restricting anything,:) I check that out also
I could just show you that it would work the same way when connecting a normal toroid choke for the Yoke.
But then I have no mediator anymore for mixing and effect.
Guessing I will make another video only about the Mediator how and what, when working with this device, it's not focusing on one thing,
it's like 2 to 3 things at the same time to reach the goal :). first I will upload another one. there will be some of your answers in it too.
Single bulbs I could Only light up almost until I reach 300W~ Bright bright  single bulb , but when reaching above that wattage, On Single Bulb It does not light.
Nor will it even without the kacher for effect, So you know now it's not like a normal mosfet mazilli circuit being connecting up bulbs in parallel to get them to light up.
My 500W incandescent bulbs wont light nor the 1Kw ones. Not yet, but soon they will ;) Just need Capacitors with larger Bigger storage.
This system is very sensitive yet it is strong but at the same time it is somehow Smart to know to set the proper loading to what you connect to it :).
As we know energy and matter carry Intelligence and Geometry too ;). they are all programmed by Creator to do what they do.
I measured 1 amp being consumed with amp clamp by the input of the PSU,
Voltage I did not dare to measure, don't know if Radiant could Rig my meter. but will try.
I do not now yet how much amps is being consumed from 24V but, but for sure it's not consuming 15 amps,
I believe it's consuming below 4.. 5.. 6 amps total. not sure.
will know soon when getting measuring material. When connect and disconnect I see how much arcing it gives and you will notice how much it draws.
Btw  the RMG system was Purely a resonant AMPS Generating system,
it was reading over 67 Amps with my capacitor array on 24V, but no Constant voltage.
but was Resonant though in a odd way.
the yoke transformer is not even warm yet, maybe the grenade slightly warm depend on how long you have it on.
Self runner will come when I reach a greater amount of output via effect. ;)  They are arriving soon.
Lets make sure I light up 500W first and I will gladly try out a self Feed.
thank you for recommendation fo TL494, but I will try to build Akula / Ruslan circuit as well to see how they do.
     Cheerz~
Hoppy
Quote from: NickZ on January 18, 2016, 09:47:22 AM
       We need to know just what it's purpose is, and what it's actually doing. It may be restricting your output, as well. Or can you still light your 1000w bulbs, not just a single 100w halogen bulb. Remember your 24v PS is providing the circuit with 15A, and 360w. But, your output is only showing partially lighting 100w bulb.
Yes Nick, he needs to compare input to output power ratio. As T1000 has said a number of times, he thinks the device needs to amplify power in order to self-loop. We do not know from his video what current his PSU is delivering, as he is not measuring anything. Therefore he does not know the power being consumed by the load or his device components, so neither do we. Lighting a 1000W halogen bulb to some unknown power level does not really help to indicate whether his device is better or worse in efficiency, than when just powering a single 60W or 100W lamp to an also unknown power level.
If for example his PSU delivers no more power to the device when the 'effect' is switched on and the bulbs shine brighter, then either the device is transferring power to the load more efficiently (reduced power consumption in the device components), or power is being amplified and its running OU. However, in order to detemine which is the case, power consumption needs to be measured for the device itself. Of course, if the device continues to run without any power supply, then the question is answered without the need for measurement.
Дядя_Вася
8) Почти всё на русском (Almost everything in Russian)
Архив видео Dally (Archive video Dally)
http://m-serge.com/youtube.html#alternativchina_dally
(Available from my home computer when he is on. You must seize the moment.)
Архив видео Капанадзе (Archive video Kapanadze)
http://m-serge.com/youtube.html#alternativchina_kapanadze
Архив видео Vasmus-a (Archive video Vasmus)
http://m-serge.com/youtube.html#alternativchina_vasmus
Моя библиотека журналов радиотехнической тематики (постоянно пополняется)
My library electronic journals subjects (constantly updated)
http://m-serge.com/radiotechnics.html#magazines
И библиотека книг радиотехнической тематики (постоянно пополняется)
And the library books radio subjects (constantly updated)
http://m-serge.com/radiotechnics.html#books
Большой архив материалов 1Гб (A large archive of materials 1Gb)
http://86.57.154.165/downloads/FreeEnergy-27.01.08.rar
NickZ
   "Btw  the RMG system was Purely a resonant AMPS Generating system". ???
    Yet, mine can provide over 1000v, depending on the load.  With no load, about 1500v.
   Your induction circuit is running at around 10khz, in the audible ranges, almost 1/2 the frequency that mine is running at (18.600Khz) for now. Just to let you know your running frequency, or at least an approximation of it.
   And your double wide Kacher secondary is most likely giving you a frequency in Khz ranges, and not Mhz. Like 500Khz, or lower.
   Just to compare notes...
   I'm curious,  as to why you think that the yoke going into the "chaotic mode", (and ringing), is a sign of resonance. Akula nor Ruslan's devices don't "ring".   At least, that I've heard.  Ruslan's most resent device runs at about 15Khz, or so. But, does not ring.  So, that's why I'm curious, as to the chaotic mode being a positive sign of resonance.  Maybe so, at certain frequencies.
  Hoppy: You mentioned: "Of course, if the device continues to run without any power supply, then the question is answered without the need for measurement."
    So true... but even then measurements would help to understand what is happening and where any "extra" energy is coming from.  Maybe putting a diode on the earth ground can help to answer that question.  Or maybe not.
GeoFusion
Nick, and all
This will answers some questions yet again for many.
part 2
https://www.youtube.com/watch?v=7ELg1TclytM
watch till end, good examples
Hoppy next vid I will Do as you asked with the antenna and for Nick, Different caps on Different Resonant Tunes.
Nick,
:/ There is no room for a Race to who gets it first or who has  more then the other or knows.
we share this for all who can. that is all and simple.
Yes it's in audible range, It's because of the Capacitor needs to be tuned to that particular freq for it to make amps, that makes it Ring like that,
If I down Tune or up tune the heavy ringing stops and no amps., it only rings heavily when reaching the resonant point of that blue cap you see for the 3 winds area.
System is now limited power because of that 1.5uF 450 volt cap.
Take a look at the URFA vids I posted , His device also has audible range of Freq, but has massive effect. because he is using different Caps
I'm sure when hooking up the 2000/700 0.47uf WIMA or similar caps the resonance tuning is somewhere els and you will hear another tone.
That I will do in the next vid with other caps for show.
Guyz I know it's hard to grasp but bear with me, Because I Don't Really know how yet or what. :/
I'm listening to my guides as they show me how to work with this. it's a learning process.
I have no idea in what Hertz range Kacher is but most important to my eye was to see the Effect is real seems easy when you know how.
it's not the same chaotic mode as what happens when you connect a Mazilli to a yoke with only parallel caps to it, this is a different story, I see it right befor my yes :/
Try my circuit out and see the potential and wierdness.
I do believe by now the extra energy is Ambient all around and collected and also from Earth ground or Big metal object.
,The Tesla coil makes it possible or some High Voltage Pulser.
But as I start to understand and saw all Ruslan's  and Roman's , it Increases energy in the Torsion field. :)
Btw my Transistor is a 2SC5200
Cheerz~   ;D
