NickZ
  Geo:
  Ok, so what you've done is to replace the normal choke that goes to the yoke's center tap, with the bigger green toroid. This toroid also has a mag wire coil which is also feeding the Kacher circuit. The main difference is the additional mag wire coil that's going to the Kacher crt, and the way that you've connected it all up.
   You may find that once you try higher wattage bulbs, which are pulling much more of a load, that your commercially made full bridge rectifier will overheat. And it may also be restricting your output, as they are designed for 50-60 hertz, and not 10.000 hertz.
   I did not see any improvement in using the 2000v WIMA caps, over the ones like what you're already using.
  I feel that the 4 recommended 6 amp diodes on a heatsink are essential for the full bridge rectifier, as even the UF series 3 amp diodes will overheat at higher loads. I am using only two 3 amp diodes, as per the earlier schematics, and they do get hot.
   I'm not into competing, or racing to see who gets to have a self runner, first. Or who knows more...  Heaven forbid!
I chose to cooperate, instead.
    The reason that I'm comparing your set up to mine, is to show the difference is running frequencies,  not to show a who has the "better effect".  As we are all interested in knowing and studying at just what frequency these circuits are working at. And if earth resonance, or it's any of it's harmonics and wave lenghts are something to tune for, or not.
magpwr
hi Geofusion,
Only 3 findings from Vasmus previous video which may or may not applicable for Akula Kapanadze device.
1)Device is connected to ground via capacitor it's never connected directly to ground.
2)Kacher is powered via bridge rectifier
3)There is nearly 2 turns for the primary driver windings for the kacher.
It seems to me the kacher in vasmus serve no purpose in transmission of RF at all.
Base on my intuition maybe this kacher role in vasmus is just to superimpose high frequency in Mhz onto the unknown pwm frequency in khz.
There is no filtering circuit at kacher.
The kacher is just powered off via the nano crystalline toroid.
If you create enough winding on a suitable toroid.In theory it can be sufficient to power the kacher via bridge rectifier and the step down winding for the center tap can what you have already done now.
But the tiny winding needs to be swapped with little thicker winding to provide enough amperage for the kacher.
Line filter for the kacher is no longer needed for the above suggestion since it's electrically isolated from the supply for the pwm driver.
Long story short-Kacher is powered from the addition of stepped up winding on toroid meant for the center tap of yoke.
Jeg
Quote from: Hoppy on January 18, 2016, 04:04:03 AM
Again I may be wrong but I have a feeling that the increased lamp brightness is as a result of the PWM imbalanced output caused by the Kacher HV on the supply lines but not directly from the Kacher induction into the grenade.
I may also be wrong but i had the same conclusion before a year, when i had fed my Katcher straight out of my 24V at the point where 24V meets my mosfets primary coils. (As Urfa had published). The increasing of the output light was due to an abnormal increase in consumption. If Geo will just connect a simple needle current meter at his device input, things will go more clear. Good job Geo, Nick. We will never surrender ;D
Hoppy
Quote from: Jeg on January 19, 2016, 03:04:17 AM
Yes, this is an essential measurement. Geo also needs to measure the current being supplied to the Kacher for both 'effect' and 'no-effect'. He should then be able to see what is causing the effect'.
Tomtech29
Hello
from my observations that trengthening is the cost 2Amper with the same power supply and is only visible to 150Watt load increased burden affects the inductance of the coil and changes the resonance frequency, but if you was wrong please correct me, I also have confusion with this connection if you have time "GeoFusion "you  fix scheme:
I think that the current measurement is a good choice analog ammeter:D:D
Overall power consumption is 6 Ampere it exceeds the value of the 100watt bulb! but I'm curious of your opinion on this topic.
