Tomtech29
Quote from: GeoFusion on January 19, 2016, 11:58:55 AM
Hi Guyz :)
Yes, What I really want is for us to put our heads together,
we are so close to know how the device works, yet for what I managed up till now.We need to do further testings on this.
   Jeg, :)
yes, I will see where I could get  analog meter Volts and amps both Dc and Ac for the further tests.
  Hoppy,
Yes measuring equipments to continue to see differences, will make sure to get them asap.
Tomtech29,
Hi there x), Yes amp analog meter is needed for measurements, I drew a schematic for you too see. down.
  Nick,
24V is fed to  Kacher input. As well PushPull. you will see in Diagram Edited on how I have everything hooked up.
Look at the Mediator connections and where effect takes place. follow the lines carefully, and see where I have it striped as example if tested.
Below here I have what is currently hooked up now. Today I will Continue with Experimentation.
Output is HV DC!!   it can be Done connecting Load to the AC lines
but DC line has better output with the proper Bipolar capacitors.
Sometimes I Have no idea what I'm expecting or what connections I might make, but It's Doing Something Exciting! :)
https://www.youtube.com/watch?v=7ELg1TclytM
            Cheerz~
hi Geo.
I do not quite understand this bridge rectifier is connected from  the positive side  (+) to the emitter of the transistor???
rather strange that this is an NPN transistor or indeed so you have connected? (Please check this 100%)
(if so is it with this voltage measurement will be difficult to Karcher ordinary tester) HV!
-Besides, if the transistor is closed, the voltage returns to the yoke on the primary windings, there appear peaks can be on one side of the transistor and therefore is one side heats up (I do not know whether the other party is able to level the playing field work) such a high voltage that you will be hard to measure pulse power Kv!!!
I have a question, or when the detachable bulb appears high voltage arc? (be careful I would not become foot on the ground) :D:
NickZ
    Tomtech:
   I have been connecting the Kacher transistor emitter, to the 0.47uf, 2000v capacitor. To one side of the cap, or the other depending on other connections. This cap is also connected to my Earth ground line. This increases the kacher's output, some how, over what it can do normally.
   So now, I've connected my older 12 yoke from the previous tests to serve as a "mediator". As it had a total of 12 turns (6 and 6), on the primary coil, and about 22 turns on the secondary. I still need to finish some connections, and then to fire it up. We'll see what that does. At least for now, I can see that my previous yoke chokes which have been replaced by this big yoke core, instead, now, the big yoke is NOT heating up, like the smaller chokes normally do.
  More to come...
Tomtech29
Quote from: NickZ on January 19, 2016, 07:33:38 PM
    Tomtech:
  More to come...
NickZ
we assume that the emitter is connected to the negative side power supply GND and an additional ground is contrary to what he said that we should not ground the power supply!
It implies that this scheme is flawed.
-but rescue us new message arrives :link containing recorded conversations with :Ruslan,not fully reveals the secrets and turns?
could do with a good translation!
I understood something about the yoke that is in two parts between them is "something" possible piece of paper ,still says something about the yoke do not know whether it is: horizontal tape as it happened as it did with Lithuania experiment!
Tesla coil control is required # 2MHz system,it's really just the LC tank does not play any role first!
the video footage shows that the longer someone replicates the system fully looped and interesting effect of working with a note "Karcher": silent on such power
but it makes mixes this frequency to tune in Radio :D (sound from the yoke sounds like noise from the speaker) chaotic's not a squeak?
very interesting touches and moves the coil and you can hear how the system adjusts itself!
-To get more power at the output must be replace "Karcher"  used this pulsar Ns.
not all the words were spoken I realized that someone had already done are not published on the Internet or have any pressure from the Mount of power afraid to spread the word or simply they want to only have it for themselves?!.
Now is the moment of euphoria, guessing who will do the correct configurations?.
Please share it what have you discovered...
Tomtech29
Hi.
I have a question for you is this chip can replace the CD4011, for example 74Ac00?
and the second is related to the push-pull (as the second transistor opens without signal The input to the driver mosfet?
