Dog-One
Quote from: N20Wolf on January 20, 2016, 06:44:43 AM
Hello! Torrent, to download files over the fuel-less generator Sergey Alexeew.
Not finding any seeders at the moment.
Jeg
Hi Itsu
(Allega's blue box)
I was wondering how did you drive 74HC00 by taking the 12V pulse output of 494, and feeding with that the 5V input of the CMOS. Did you use any kind of transistor, transforming 12V to a 5V pulse?
Did you make it  by resistor divider ( R2,R4)?
Tnks
AlienGrey
Zero point energy, where does it come from ? is it background energy from when the earth was created or is it constantly being created (thus making the conservation of cosmic energy necessary) ?
Dr Thorsten Ludwig - Zero point energy, The view point of modern physics on the sea of energy
Well watch this and find out !  https://www.youtube.com/watch?v=bCvbqMGPpa8
itsu
Quote from: Jeg on January 21, 2016, 02:36:19 AM
Hi Itsu
(Allega's blue box)
Tnks
Hi Jeg,
no, i did not use anything else then whats in the blue box, so i guess the R2,R4 and/or the 1n4148 diodes are taking care for that.
The output of my little TL494 circuit feeds into 2 MOSFET drivers (UCC37322) and are also fed at that point (via a switch) to the blue box.
I don't know right now what level of output that TL494 circuit has.
By the way, i am using a 74HC132
Itsu
NickZ
  So, I made a "mediator" coil out of my older 12v Tv yoke from the previous tests. It has 12 turns on one coil, and 22 turns on the other side of the yoke coils.  I don't notice any benefit from taking the Kacher's circuit input from the 22 turns coil side of the yoke core, and also not much from the 12 turns side, either. But, my regular 24v yoke is not able to go into the chaotic mode now. And my two mosfets are heating up. One fet more than the other.  Like Geos do. Although the big mediator choke is not heating up, like the smaller chokes that I had on before did.
  However, there does seam to be a higher degree of sync with this set up, between my Kacher, and the induction circuit. But, I need more time to tune the device, using tuning caps, to see IF there's any additional output at the bulbs.
In any case, I need some more time to work on all of this, to see any real "effect".
  BTW: I do have one of those 1 1/2 inch green toroids, but I can't find it right now. I tried a smaller green toroid, also, but it heated up too much.
  EDIT:  The device started up into a strongly felt "Vibrating" mode. And I let it run in that mode for a minute or two. until one of my fets started to smoke. Of course now the device does not start, at all. I'll replace that fet, and try not go into that mode again, at least not for longer than a few seconds.
  What is the value of the diode that is to be use at the PS?  10A???
   Any one else working on this mediator coil set up?
