0 Members and 397 Guests are viewing this topic.
Hoppy
Quote from: NickZ on April 30, 2013, 06:26:29 PM
   Hoppy:
   He is showing that he can light two small bulbs with his power supply. But, doing it with all those straggly wires,  is really something.  Kind of what Romanovs is showing, but he's using over 3 amps to light one bulb.  Free energy at last.... well, I had to open that bottle.
MenofFather
Quote from: NickZ on May 01, 2013, 02:11:43 AM
   MenofFather:
   The hand drawn diagram is the same that is supposed to be from Akula 0083, but the top additional part is not the same (black ink). Hard for me to understand what is written there, maybe you can help. But, I don't want to get fooled by that diagram, as it may not work as shown, either. So, I'm trying to figure it out, by myself.
   I've studied some of Akula's previous videos, to see how he came to the conclusion of the last (self runner) video. He did not get there overnight.
What I see is that the yoke is pulsed by a high voltage driver, which is connected to the e center tap of the yoke. The yoke is acting as as step down transformer that increases the current, while dropping the high voltage. Then the three turns on the yoke should go to the big AC cap (possibly). Then further to the big air coil secondary.  That is where the mistery lies.  That part of the big air coil looks very similar to all the other replications of the Kapanadze, or kapagen device coils. Same as all the previous replications that did not work out, also.  What is missing, what is the missing link?  I'm working on it...
If you scary be fooled, then you be fooled. This diagram i check and it seems corect. From inverter going to bridge, and then to mosfets. Generator how I understand is about 1-16 kiloherc and it suppled from 12 volts about. Youke have yelow about 16-25 turns maybe. Red wire on youke not used, how I understand. White wire with green isolation is three turns and go then to red inductor trhouth capasitor not polar. Yellow winding in buttom is going to brigde resctifer and to capasitor for smooth pulses and then to inverter and to supply generator 12 volts, who pumping 300 volts mosfets let say (with AC curent seems, hight frenquency (1-16 kiloherc like write)). White wire is on whole pipe and it go to lamp top conection and buttom conection to minus and to lamps. Drossel in inside pipe like I write in other post and how I understand to it in paralell conected capasitor. In henderschoot generator is also one winding who not either conected only to capasitor. Whats all seems.
MenofFather
Drosel conected to capasitor. Akula says in video, that who knowh about Hendershot generator, his knowh why need drosel in same magnetic fields or something about similiar...
MenofFather
Drosel or winding to not something conected, only to capasitor.
d3x0r
Quote from: MenofFather on May 01, 2013, 04:26:20 AM
That is a hendershot generator schematic.
The capacitor is long foil wound on a ferrous bobbin inside the basket weave coil....
Sorry got interrupted.
The capacitor will be influenced by the coil; since there must be a net charge in the windings, it's going to affect the behavior of the capacitor.  I think there's a capacitor trap (captret? no I think that's wrong) but charging a capacitor with a wire mesh around the outside.
that is the part that whatshisface (recent replication) says is in the center of his.
