0 Members and 28 Guests are viewing this topic.
GeoFusion
John.K1,
part 1
https://www.youtube.com/watch?v=qEHKGSLy938
part 2
https://www.youtube.com/watch?v=7ELg1TclytM
If we take a look, Tesla coil on it's own is OU, for generating HV in great amounts. It Pulls ambient towards it, like a vacuum.
we see that when we see the Purple Corona at the ends.
I know Ruslan told us about Pachky impulsov , I think it is to multiplication within the electrostatic field within the field for effect.
not sure.
Below I have a schematic of what I have currently on my bench. with Mediator core for Synchronizatie
John.K1
Geo: I tell you what I think-  Packy impulsov- UNIPOLAR impulses on antenna  = one plate of capacitor.    Grenade coil  = second plate of the coil.   So we got a asymmetric capacitor- you can read about its advantage in Utkins papers.  Why uni-polar impulses?  Because we want to have only one type of charge on the antenna so the other charge on much bigger surface can form from ambient.   And now why do I think this way?    Akula- is speaking about them, Ruslan is speaking about them saying the people unfortunately still omitt this important information (eto k sazelenju  on skazal  :)  )    This guy speaks about it such a way as he knows for sure  :  https://www.youtube.com/watch?v=VGuw3QvoseI   and the last is Stan Mayer using very same principle just in different device.
Capacitor - very simple- no magic waves and all that crap. Attract the negative electrons from ground as much as you can thanks to the thick wire.
That's the flow of my thoughts and that's what I will start to work on tomorrow again.
GeoFusion
John.K1
:) yes we got a asymmetric capacitor being formed. I did folow Akula and Ruslan, Also read Utkins papers,
have done some of his experiments  , but yes unipolar impulses is needed :).
You know befor I connected the Kacher to Grenade
I experimented with kacher this way, just like this man.
vid below.
https://www.youtube.com/watch?v=_R0HQksUSeY
Then I knew Grenade was asymmetric capacitor, ground is the negative charges that is why it needed :), i know.
Yes, lets  continue the experimentations, we have all the info we need now, but alot of experimentation required.
This guyz also managed Effect :)
https://www.youtube.com/watch?v=faCaYvh69Bs
John.K1
Thanks Geo. It looks like we are on the same wave :D   Now the question is how to create that uni-polar pulses. My guess is they are formed on the  ferite rod between the Tesla and antenna. My previous experiment some time back was unfortunately  unsuccessful ;( Any idea?  I can get them easily on the toroid with two coils.
Dog-One
Here's a comment from Ruslan that I think needs to be studied:
Quote from: Ruslan Kulabuhov
So I understand that you are still looking for the impulses? Stop this stupid experiment was carried out on the system. All wrong. Powered magnetic field. Current voltage is subject to Tesla. It is for this reason that the scheme is Kacher Sharks. He is always in resonance. So stress is always in the "Antenna" current in the transistor base. So it is working Kacher. Just all the hammering impulse without examining the AC Tesla pump and so on.
Pumping of the inverter at low cost creates a strong current in the wire, and therefore the magnetic field induces crazy. As we can see from the rollers and Roman Kapanadze, the inductor is always on the side !!! That this is necessary to understand all of you. Why ? Why such a magnetic field! How does it help us to get inexpensively free energy generator. Open the curtain ... This system reminds us of a normal generator. Where the rotor turns inside the stator. Stator - detachable coil, rotor - magnetic field, moving inside. And what drives the magnetic field inside the stator in this system? Turn the head at last! Tip 2: How to influence current tension, especially in the half-wave?!
So the inductor having heavy current is on the side (not the middle and not across the whole grenade or Dally coil) and for good reason.  This heavy current is where the strong magnetic field comes from.  I have proven more than once this is the "force" that will heat a steel screw driver.  Ruslan is implying this magnetic field is driven by the charge during the half cycle of resonant oscillation.  I'm assuming if you don't drive it, then it will just sit there in-place.  If you do drive it, then it must enter the wire and become real electrical current at the load.
So close to understanding what electricity is and how it actually works, but not quite there yet.  If we can just understand this, building OU devices should be child's play.
