0 Members and 144 Guests are viewing this topic.
John.K1
Quote from: Jeg on January 23, 2016, 03:37:49 AM
Hi JohnK1, Geo
I spent a lot of time to make unipolar pulses at katcher's output. The only way i did it was when i intercepted a diode between katcher coil and antenna, and adding in addition a small cap between antenna and ground.
Hi Jeg, I just spend couple hours trying to figure out how to get uni-polar pulses.  As you can see on my picture below I can get some sort of pulses similar to uni-polar but not exactly. I still have a big negative peek. No diodes ,no capacitor. Just signal generator on my Tesla's primary and scope on the output behind the ferite rod on Tesla (before antenna)  I just wanted to see the effect of that ferite rod. Unfortunately I can't see any so far. To get pulses as on my picture I first found a resonant frequency of my grounded Tesla coil (2.665MHz) and than I tried its harmonics (5th & 10th down) and than I tuned a duty cycle.   That's what the guy said in the movie - His word : "  here you can see you can get a Uni-polar pulses on LC tank circuit.  ..."    He also tned to 5th and 10th harmonic as Ruslan suggested.   Anyway , still lots of work in front of us.
Cheers,
Jan
Dog-One
Just keep in mind DC signals are composed of AC harmonics.
I think the whole trick to it is having the proper pulse width for each harmonic, then when they combine you get something very similar to a typical digital square wave with an offset voltage.  I watched Erfinder do this with his coils, but he didn't explain exactly how he did it.
https://vimeo.com/115816020
John.K1
Hi Dog-  Interesting-  There are constructive and destructive harmonics. Just wonder if there is any chance to suppress those destructive ones  (odd harmonics)?  Also, what is the reason of the opposite wound coil at the end of Tesla coil of Ruslan's device?
Dog-One
Quote from: John.K1 on January 24, 2016, 02:19:47 AM
I can't say for sure, but I bet it's the same reason the grenade coil has 96 turns in one direction and 72 turns in the other.  Must have to do with setting the proper inductance to achieve the desired running frequency while still maintaining the proper wire length.
I've been trying to deeply analyze the construction of the grenade coil and if my hunch is correct, this is a very sophisticated coil--turn ratios, wire length, velocity factor, turns direction, inductance, impedance, magnetic & charge influence, they all have to be just so to even allow the effect to manifest inside.  That in itself is difficult enough, then you have to drive this coil properly.  It's really making my head hurt.  Whoever came up with this gadget really understood a lot about electricity.  I can promise you, not even TinselKoala could figure out what all it's doing in a day or two--probably why he hasn't elected to hop onboard, because it would show just how much he doesn't know.   ;)
John.K1
Quote from: Dog-One on January 24, 2016, 02:35:03 AM
Ruslan corrected him self saying it was wrong design. His new grenade is wound as a normal transformer (back and forward for all three section) as far as I know.  he said the old design was very unstable. I am going to make a newcoil today. I still have a old design too.
