0 Members and 120 Guests are viewing this topic.
John.K1
That sucks. I made a long message with video references and translations etc.- It took me 1/2 hour to make it and when I clicked the save button all is lost due to time Log out. :(  Ok sometime next time. :(
Tomtech29
suggest that the scheme need to use:(enter it here)
I confused
Quote from: magpwr on January 23, 2016, 07:22:15 AM
hi Tomtech29 and everyone,
I have attached waveform and circuit diagram as downloaded from the huge torrent related to Sergey.
The circuit diagram was only revealed for a brief moment in one of the Russian video discussion as found in the torrent download.
2 things to note
1)Base on waveform sergey is using 1/100 ratio for the frequency.If the tesla frequency 1.66Mhz the pwm frequency is 16.663khz.The only thing i can't tell if the frequency in Mhz is derived from interrupter pulse ,harmonics or just tesla frequency.
2)Sergey circuit although i got no time to study this it would be likely generating few interrupter pulse say 5...9pulse in a row.
  If you are familiar with tesla coil and interrupter circuit.I think Sergey is running this interrupter pulse at tesla coil resonance but using only 5...9 pulses in a row,in nanosecond.
"Like he is aiming for nearly maximum point and not going further."
Oleg circuit merely generate single nanosecond pulse compared to Sergey's circuit.
But i do find it strange Sergey's circuit did not Superimpose high frequency in Mhz to center tap.Worst there is no choke implemented.Maybe this was his early design.
My last experiment with "Tesla Transponder 2.0" circuit with interrupter pulse (10...20pulse in a row)without kapanadze coil yield max 32Amps to Earth .Power using full bridge rectifier from a high power 12 to 220volts inverter.
Interrupter circuit does produce little better output at a cost of increased current draw.
All the while my primary aim without dabbling further was just to get some spark from the ferrite rod which i had failed miserly."This was the test Akula did before even providing power to the bulbs in the old video"
After watching the recent video of Geofusion.This gave me hope to complete this feat successfully at least. :D :D :D .
I have no such experience in building PCB and I have so far not managed to put together even one efficient controller to Tesla!
I care that it was such scheme in such form as above where I know where paths ( strange Sergey's circuit ) drawn with pen does not appeal to me!
I know it may seem ridiculous,these logic gates-background checker:D
-I would like to make a controller that could perform several experiments on the Tesla coil .
You suggest that a good start is a single pulse Ok.
would you how to control this Tesla? where should I start / guys suggest unipolar?
-pulse packages or single?
Thank you all.
John.K1
Hi Tom
About the pulses- start with this info. Think about train of pulses.probably unipolar pulses.  Ruslan shows a difference of this pulses between in phase and out of phase with the current wave. I think he says he takes a picture of pulses from the gate of his transistor. That video was here already but is not any more on YouTube.
https://www.dropbox.com/s/p064duendpvhowy/%D0%AD%D1%84%D1%84%D0%B5%D0%BA%D1%82.mp4?dl=0
Dog, Jeg other- in short what I wanted to write before. If the grenade coil is wound as a normal transformer, how do you inductively de-couple  between the current coil? How should current coil be wound like?  In other word- how to wide bifilar with one wire?  It confuse me.
Thanks.
NickZ
   Since no one has managed to see any amplification effect (OU), from the simple Kacher circuit, or winding the grenade coils in either way. Why would you want to make the much more complicated pulse train system for the Kacher?
Get it working, first, like Ruslan showed as a simple Kacher crt, then make the more complicated set up, once you have the Kacher circuit working. Not before, like you're all trying to do. Or you may get stuck, where you all are right now.  Burning out components, and going no where.
  We need to start simple. It took several years to perfect this all to the point it is being shown now. Thanks to Oleg, and Ruslan.
But, we still aren't seeing or obtaining the desired "effect", at all.
   Geo: You're partially lighting less than 100w worth of bulbs while using a 360 watt PS.
If the effect is to happen, we need to show it lighting more bulbs than the input power that is being provided for.
   I don't see any Magic in the mediator, as it is not working as a normal choke, and allowing more current to pass into the circuit, and burning out the fets, or overheating components.
   I found my green toroid, but it is not as big as yours. Only about an 1 1/4 inches, or so. I had it mounted onto the device, to see the current wave form of the grenade.  I'll try that core out next, once I get my device working again.
   I've replaced the fets, and it still won't fire up. I still don't know what's up with that.  The strong vibration from the yoke killed more than just the fets.  Beware!!!
Hoppy
Quote from: NickZ on January 24, 2016, 10:22:38 AM
Nick,
I was of the understanding that Geo has seen the desired effect. Although you say that Geo is using a high powered supply, he / we do not yet know how much power his PSU is supplying, or how much power his load is consuming. His next video should shed some light on this as he says he will be taking measurements. Don't assume that a 360W PSU is actually delivering 360W or anywhere close to its rating to Geo's device. I get the distinct impression that you still do not understand power.
Your mosfets are most likely being destroyed by high voltage, not current through the introduction of the mediator.
