0 Members and 1192 Guests are viewing this topic.
Tomtech29
Hi. NickZ
you ask why I wade further with a complex system, I believe that the circuit Kacher is just an example of how to find the pulse point.
there is no system using a looped.
so really the power that we have the same reservoir LC It is not comparable to the example Ruslan! It fires from the yoke of 650 Watts without reinforcement!
It is more efficient!
What is behind the winding inductance type grenade?
-now we use resonance to until extinction/I do not understand what it's like for him that does not happen?
the second thing is to maintain the resonance to be out of tune.
The pulse system is second to none I would like to come up with what to do with these impulses / He conducted an experiment on different types of coils
and I found that the pulses appear after bridge rectifier at the output of coil but this arrangement inductive (I connected the same yoke 28 directly to the inductor) using ZVS the capacity of the inductor 28 closes rotation I observed considerable power! at 8kHz. and connected the output of the second coil is on the bridge appears in DC and beyond the high-voltage rock peaks!
Now the :"Dog one" He showed me that mustache on top of the current! More Kacher will not help because you will only see the effect of increased tension! and as the voltage is reversed magnetic field of the inductor?
you find that to insist but one of the oscilloscope line video can be seen opposite the bell!
still I do not know how this bell to get on Tesla?
Primary Dally is based on pulsed and that to hold that!
(he was so short material to align Kacher and pulses at the base of transistor le not show what is happening on the air signal penetrating into the tank :;D)
Jeg
Quote from: John.K1 on January 24, 2016, 09:35:36 AM
Dog, Jeg other- in short what I wanted to write before. If the grenade coil is wound as a normal transformer, how do you inductively de-couple  between the current coil? How should current coil be wound like?  In other word- how to wide bifilar with one wire?  It confuse me.
Thanks.
John, a coil with two opposite direction layers can be called as a current coil only when using it as a choke and not as a secondary like grenade is. This is because when you inject a signal through it, voltage is being canceled out between the opposite turns, so there is not any significant magnetic field to the choke and so current passes free with no drag.
Looking from my mistakes the last couple of years, I now think that there is not any real reason to have my grenade opposite wounded. In fact now that I see the device as a Bemf gen, one direction winding will give higher bemf peaks. Simple logic.
May I ask something? Is anyone here that have tuned his inductor coil to the same frequency like grenade? If not, then why do you care about related wavelength for inductor?
Jeg
In other words. If inductor is to be tuned in series with a cap at low KHz, why does it need to be wavelength related with grenade?
John.K1
Quote from: Jeg on January 24, 2016, 12:33:26 PM
Hi Jeg, it is actually coincidence as I spot the answer for your question in Ruslans video today. In some of his last vidoe he says the granade can have any frequency what ever capacitor you use (if I right understood -Russian is not my native language :)  )   He says important is to get a synchronization between Tesla and current LC loop.
If this can help.
Edit1:
So if I right understund my Grenade coil will be like a normal wound like a normal transformer - how is normal ransformer wound?  Back and forward?  That what he show with his finger -right?  So the direction of my first layer will be a reference for opposite direction of current coil?
As very important he see the effect of the increasing of magneic field due to HV pulse. That's what is the last video about . He says the pulses in anti-phase does the effect.  I do not see it-I do not know what should I look for as both -in phase and anti-phase they looks similar. Check the increase of frequency when he fires  pulses. It increase almost double.
Jeg
Quote from: John.K1 on January 24, 2016, 12:48:50 PM
If this can help.
Thanks John. What do you think that sync means? I know that when we interest about specific wavelength in a coil, then it is because it has to be able to vibrate at this frequency. Can your inductor ring at this MHz frequency?
