0 Members and 23 Guests are viewing this topic.
John.K1
Quote from: Jeg on January 24, 2016, 12:55:28 PM
Thanks John. What do you think that sync means? I know that when we interest about specific wavelength in a coil, then it is because it has to be able to vibrate at this frequency. Can your inductor ring at this MHz frequency?
Jeg, I think as I said in my previous edited answer, the important is to increase the magnetic field by firing the HV  pulses (that's what he says).  I am not sure about it. Not sure how can pulse increase magnetic field. Maybe it can.  My opinion is more like electrons accelerator? :)
He calls antenna a Plate of capacitor. Exactly as some of us here - forming  Asymetrical capacior.
Why MHz on inductor?  There should be KHz range -no?
nelsonrochaa
Quote from: Tomtech29 on January 24, 2016, 11:59:05 AM
Hi. NickZ
you ask why I wade further with a complex system, I believe that the circuit Kacher is just an example of how to find the pulse point.
there is no system using a looped.
so really the power that we have the same reservoir LC It is not comparable to the example Ruslan! It fires from the yoke of 650 Watts without reinforcement!
It is more efficient!
What is behind the winding inductance type grenade?
-now we use resonance to until extinction/I do not understand what it's like for him that does not happen?
the second thing is to maintain the resonance to be out of tune.
The pulse system is second to none I would like to come up with what to do with these impulses / He conducted an experiment on different types of coils
and I found that the pulses appear after bridge rectifier at the output of coil but this arrangement inductive (I connected the same yoke 28 directly to the inductor) using ZVS the capacity of the inductor 28 closes rotation I observed considerable power! at 8kHz. and connected the output of the second coil is on the bridge appears in DC and beyond the high-voltage rock peaks!
Now the :"Dog one" He showed me that mustache on top of the current! More Kacher will not help because you will only see the effect of increased tension! and as the voltage is reversed magnetic field of the inductor?
you find that to insist but one of the oscilloscope line video can be seen opposite the bell!
still I do not know how this bell to get on Tesla?
Primary Dally is based on pulsed and that to hold that!
(he was so short material to align Kacher and pulses at the base of transistor le not show what is happening on the air signal penetrating into the tank :;D)
Finaly someone put brain work ! 😀  i sad months ago that same effect could be reproduced without
Ruslan coil configuration ...  Is not the coil but the effect .
But well, people just copy  .. But if stop a bit to think by own  maybe it could achive better results but well , maybe this área of research is not to everyone 😉
Jeg
Quote from: John.K1 on January 24, 2016, 01:14:02 PM
I see that vibrates at KHz due to series resonance. But even if it wasn't wavelength related to grenade, then again it would be able to vibrate at KHz due to the series resonance. There is not any sense for inductor to be wavelength related to grenade if it wasn't be for vibrating at MHz. Don't you see the hole??
Tomtech29
hi
"John, a coil with two opposite direction layers can be called as a current coil only when using it as a choke and not as a secondary like grenade is. This is because when you inject a signal through it, voltage is being canceled out between the opposite turns, so there is not any significant magnetic field to the choke and so current passes free with no drag."
some truth in this is ,once I tested a simple coil in the same direction I had weaker results! (I had the impression that when the load coil is greater toll on the disadvantage LC) This means the load grenade and inductor gets ass :D
NickZ
    Jeg:
   That's why it has to be a harmonic of it, and not the same frequency. As the induction circuit of the 3 turns coil. won't reach the same Mhz frequencies, with the recommended windings, and doesn't need to, anyway. But, in any case the Kacher circuit won't do much at higher Mhz frequencies. Like 2.6Mhz, or higher.
  I think that Itsu gave something like that a try, (same frequencies tests), but I don't remember how it all went.
Maybe he can explain it better.
   Hoppy:   Lighting up a bulb or bulbs with more than their needed input power from a PS, does not really show an "effect"?
The effect should produce more that what the input source provided can provide. Or not? So, place more than 360w worth of bulbs on it, not 100w.
I'm not assuming anything, as yet. One way or the other.
  But, I'd like to see more output from a device than what a PS can provide to it, as proof of anything.
   I still don't get the OU, part.  As it has been mentioned that in order to see an effect, that will allow a device to self run, first, it has to provide more power out, than in.  Not just a brighter 100w bulb, that is still not fully lit, by the 360w supply. Even the measurement won't be enough for me,  that in itself is not enough, to show the needed effect.  Self running will do it though.
   However, I'm not knocking what's been shown, and do appreciate it. And, I'm also waiting to see what the long term effects of the mediator (mixing voltage with current) in that way will do to the device and it's components.
   I still can't get mine to fire up again. After is went into the vibration mode,  like you like to see.
I should of made a video of it.  The vibrating dance of death.
  Somewhere in my device there is still a short circuit, but things look ok, so far, I haven't been able to find it yet.
  I've replace both fets, and there's still something shorting out. I'll get it though...
