John.K1
Quote from: Tomtech29 on January 24, 2016, 02:10:24 PM
all
I do not want to be pushy but I'd love of the yoke and the tank fire as he 650Watt!
Note that it does not fall so ampere and he says that is not connected transistor from Kacher So where is the truth I ask?
https://www.youtube.com/watch?v=NHpUE6oqt7k
9:15
such an effect, no one showed and from that we start the conversation gentlemen?
Hi Tom, If I good understand, he says he left Kacher and using  HV control unit.  This is why he has a transistor from Kacher alone.
NickZ
  Hoppy:
  Although being able to get good spark off of the ferrite rod does not proof anything special, it does show that there is enough intensity of spark to be able to do it's job. To some degree. We still don't know what the HV intensity minimum levels need to be.
  And whatever that ferrite rod is doing to the output, one thing I can see is that the HV stinging, is much more intense, and hard to take onto ones finger, for more that a second, or two.
  I have to say that although it may sound like I'm maybe not too impressed by the last videos, by Geo, and others.  I really am.
And, he deserves some merit, for doing what has done up to now, even without a scope, frequency analyzer, signal generator, etz... My hats off to you, Geo, and anyone else still working on this.
  Jeg:  I thought the same concerning tuning using caps to obtain the wanted frequency. But, if the winding counts are way off, the tuning caps may not make up for it.
  Isn't THAT,  what the TL494 circuit is supposed to be doing?
   I use ferrite in the grenade core, and magnetite on the yoke, to adjust the induction circuit frequency. So, not too many components to fry out, when resonance really kicks in. Which I've seen it do it a couple of times, kick into a much higher resonant point. But I haven't been able to maintain it for more than a second, and it dies out, and losses the sync. As if it lacks guts.
   My Kacher can be controlled from about 1Mhz to almost 2Mhz, just by moving the ferrite pieces in the core.
   Notice how long Ruslan's last Kacher secondary coil is. Almost as wide as the grenade.
So, it's probably not running in the Mhz range. But, in Khz instead.  Like Geo's 10 Khz induction circuit, or so, and he is also using a double wide Kacher secondary coil to sync with his induction circuit. Like Ursa or Urfa, has, also.
  The guys with the effect...  there are several others, as well,  on YouTube now.
NickZ
Quote from: John.K1 on January 24, 2016, 03:39:46 PM
Nick, Can I fit 10 x jouel thiefs each 10W consumption and powering 100W bulb on one plate and call it one device?? :)  (this is what I was approximately getting at the time I was messing with this stuff)
Guys, Just forget about the bulbs as a measurement device. It says nothing. When you ,make a video, use the meters to show what is going IN and OUT. Not a light on the bulb.
   John K1:
   I think that we get the point about measurements, and all. But, you should do this yourself, first, to see how it's not so easy in practice, as it may seams in theory.
  There is probably a good reason why the output power has never been shown, on any of the Akula/Ruslan devices, by any one, as compared to the input. At least not yet.
Try it, and see.
John.K1
Quote from: NickZ on January 24, 2016, 05:07:56 PM
   John K1:
Try it, and see.
I did nick ;)
NickZ
   And you found it to be way under-unity? Like most everyone else that has tried to do so. But, what does that prove?
  Ruslan's devices may also show underunity, as well, if measured by normal standards, but they can self run, when he pulls the plug.
   It will take one of us to measure the levels. That is, when some one really has something to measure.
   It will come...
   You said, don't let the bulb brightness be your guide.  Of course not!  That's what I've been mentioning all along.
But, maybe think about making it self run, first. Then measure it all you want, after that.
Or before that, also,  it's up to you.
