0 Members and 293 Guests are viewing this topic.
magpwr
hi Tomtech29,
Base on my last finding using interrupter pulse to tesla coil did produce better spark output.The Tesla coil was powered by 30volts.
But using only 30volts with interrupter produce mere 0.28Amps to Earth."If we disregard the reading error".If there no interrupter circuit involved there is hardly any current movement detected to Earth.
Since we may roughly know that kacher of those Russian device eg:Vasmus,Akula and Sergey is powered using near 100volts dc to 200volts dc max.
Sergey circuit as attached by me  previously the capacitor value is  rated 100volts.We can guess from there.
Vasmus is using either BEMF or winding to step up votlage via toroid to power the kacher via full bridge rectifier.There is only 2 wires positive and negative and no third wiring to Earth from tesla coil.
Last night i was merely researching into various  CFL circuits which was used in Resonator portion of Vasmus device  ."If we disregard the reading error".  Since we may roughly know that kacher of those Russian device eg:Vasmus,Akula and Sergey is powered using near 100volts dc to 200volts dc max. Sergey circuit as attached by me  previously the capacitor value is  rated 100volts.We can guess from there.  Vasmus is using either BEMF or step up via toroid to power the kacher via full bridge rectifier.
Last night i merely look at various   cfl circuit http://www.pavouk.org/hw/lamp/en_index.htmIt looks like the resonator circuit which the full-bridge recitifier is already built in is also being powered off from multiple windings from the toroid either via BEMF or mere step up action.
I do notice certain device of Akula (low powered Led ones) and Vasmus device is merely tapping/obtaining voltage or power from BEMF or step up.Common pattern i noticed among this circuits that it do not obtain power directly from input battery supply.
Think about it 9volts battery can never power a CFL circuit or kacher directly in order to produce sufficient higher voltage.The 9volts battery just do not have enough amps in the long run.
I am still lacking knowledge at this point on how to draw more current from Earth with the aid of the receiver coil eg:Kapanadze winding and convert it to usable voltage.
ln Vasmus circuit i can easily tell circuit was drawn wrongly base on how kacher tap power.
The most interesting part of the vasmus circuit is the 2 receiver coil and the control circuit using the vintage pot R8 to control the returning/sending pulse.
The common things to note base on observation of the Akula demo in Germany using cfl and this vasmus circuit is the "Input battery supply negative is Earthed" as well.[/quote]
Tomtech29
Quote from: John.K1 on January 24, 2016, 03:49:08 PM
Hi Tom, If I good understand, he says he left Kacher and using  HV control unit.  This is why he has a transistor from Kacher alone.
Well, I see that hand holding a transistor to be a Tesla
Tesla here has nothing to do
- bulb turns that are much more than 650 watts Thick has 500 watts to say nothing of the rest! and it is only thanks to the push pull with PLL focus!
and we can not 300 watts light of what we're talking here You say that the power light bulbs It's no good measurement Ok. is that right but :take the challenge and tell if there is a load?
-and despite the brightness drops a further bulb, however, not completely extinguished,so we have amperage and voltage has come up with Tesla
could be.......?
so what I saw it looks and not on one of the video I think, and so the same push-pull has a higher capacity than we have alone; tell me how much fire up the bulbs in the system :please use 24 volt and 6 ampere :D
-each of you has a different opinion I respect this! Nick insists on the spark ok :D raises the question and if:
Tomtech29
Hi.
magpwr
Start with a 9 volt battery is low even for relay :D
but it can be used this type of feedback signal:https://www.youtube.com/watch?v=qmK9Hn01qw4
I'm giving you the possibility to accelerate the oscillation and energy storage This energy in these capacitors must return to the source!
hear rattle////Relay until until there came a moment transformer saturation!
as there is no one tried.
magpwr
Quote from: Tomtech29 on January 24, 2016, 09:14:34 PM
Hi.
magpwr
hi Tomtech29,
There is something different about Sergey circuit compared to drawn circuit of Ruslan or Akula.
I forgot to mention something related to new findings previously-
"One end of multilayer coil is earthed" and "another end of multilayer coil is earthed as well after going through the full-bridge rectifier back to earth.
That's all for now...
NickZ
  Tomtech:
   I'm not insisting on the "sparks", or on anything. I just notice that these stinging sparks across the ferrite bar are a good sign, as far as I can see.
No sparks, can indicate that there's not enough output power from the Kacher, for any effective interaction.
The sparks are just another sign, or indicator, like the sparks that Akula and Ruslan have shown on their videos. They're no guarantee of being at the right running frequency, but they can help to visually see when there may be sufficient voltage and amperage levels, to do their required job.
  So, it looks like the Kacher only has to sync with the 3 turns coil. But, the 3 turns coil has to resonate with the 168 turns grenade output coil, as well.  Please correct me if I'm wrong, or have misunderstood.
I wish that I could understand the Russian videos, better,  as they're all Greek,  to me.  But, I'm doing what I can.
  Geo: Here's my new green ferrite core "mediator". (pic below) I could only fit 10 turns of the thick wire, and about 45 turns on the mag wire coil.  I'll see what it will do, when I fix my Mazilli, which looks like it has a burned out 18v zener, and some thing causing a short somewhere. I'm working on it, and will install the mediator when I get it all working again.
