0 Members and 290 Guests are viewing this topic.
AlienGrey
Nick Z this is for you !
you want to under stand to under stand means to do what you are told to stand under it's a verbal contract a trick to enslave you by your own answere.
That over have you got google on your computer ? it will translate it for you, if the video has got cc, click it but click translate first. I have said this a few times now ! ;)
such is life try it it works for me quite well.
Hoppy
Nick,
I had excellent interaction with no visible sparks drawn from the ferrite.
Dog-One
Quote from: AlienGrey on January 25, 2016, 03:39:09 AM
Yes, it's better than nothing for sure.  I'd still like to see T-1000 or Wesley really dig out the good stuff and translate it to English.  I'm sure the majority of us have missed many important details causing us to spend many hours experimenting.
John.K1
Hi Guys.  That CC is just around 80% precise. Some nonsense's comes out of it. But as you say, better than nothing.
I_got_a_feeling...(sing with me :)   )  Now seriously, I got some feeling - still in my head what Ruslan said about his device on the forum -it is a mixer of Longitudinal and Transverse waves.
Ok , I just make a new coil of thicker wire and wound as a normal transformer. I did a quick calculation for "Fundamental" frequency for the length of 37m for sound in copper and sound in the air   (4760 Vs 343.3)  and I end up  with the common frequency 22.082KHz.
What the coincidence ,when you take a look at the Ruslan's video,showing mixture of HV impulses to the frequency on the current coil. And what is the frequency on the current coil? Down in the corner of his screen? Yep- 22.8KHz.
Shouldn't Ruslan run the frequency on the yoke around 13-15KHz? (100:1)   . Just wanted to share some interesting coincidence.
NickZ
  Hoppy:
  The size of the spark or stream is determined by the voltage and amperage provided to it. One can therefore easily see that when there is enough intensity of spark, that there is enough power behind it. But, what causes the wanted effect is the frequency of that steamer.
  Your Kacher was more than likely running at the right frequency, or very close to it, even though it had a weak streamer.
  Seeing no spark at the rod,  is not a good sign, from what I've seen. But, if you're happy with that, good.
  Both Akula and Ruslan are showing these sparks, and steamers for a reason.  You can disregard that, if you like.
   John K2:
   Every device that Ruslan has come up with is running on a different frequency.  He started with 27.3Khz,  then changed to 15kHz. And his HV is also changing, to match the induction circuit.
    Both my yoke induction circuits are running at the SAME frequency. Which is determined by the Mazilli driver, and it's tuning caps.
   We need to tune the Kacher to the 3 turns coil. But, both induction circuits also need to be in sync with each other at their best resonant point, first, by using the 0.47uf 2000v tuning caps in series, and the 0.15uf 2000v cap in parallel to the 168t coil. Along with any other HV caps that will work to adjust the frequency.  Correct me if I'm wrong.
