0 Members and 28 Guests are viewing this topic.
Tomtech29
Quote from: John.K1 on January 25, 2016, 04:51:32 AM
Hi Guys.  That CC is just around 80% precise. Some nonsense's comes out of it. But as you say, better than nothing.
I_got_a_feeling...(sing with me :)   )  Now seriously, I got some feeling - still in my head what Ruslan said about his device on the forum -it is a mixer of Longitudinal and Transverse waves.
Ok , I just make a new coil of thicker wire and wound as a normal transformer. I did a quick calculation for "Fundamental" frequency for the length of 37m for sound in copper and sound in the air   (4760 Vs 343.3)  and I end up  with the common frequency 22.082KHz.
What the coincidence ,when you take a look at the Ruslan's video,showing mixture of HV impulses to the frequency on the current coil. And what is the frequency on the current coil? Down in the corner of his screen? Yep- 22.8KHz.
Shouldn't Ruslan run the frequency on the yoke around 13-15KHz? (100:1)   . Just wanted to share some interesting coincidence.
I hope that you will realize that it's 100% 1260Watt fires from the yoke! due to a synchronization of current in the LC tank!
This small toroid connected to the push-pull Why resonance with him does not fade ? (PLL) how to do it?
We see one capacitor of the LC tank and two other circuit 28T.
screenshots show signal from the circuit LC on the cable from the yoke 3 T
and the same voltage(sinusoidal).
Tesla gives only a flash of light bulbs, because the current is already in the tank ,as if that was not enough just 6 Ampere
nothing new !
Dog-One
@NickZ
I think you're mostly correct, but I must add:  I think the pulse shape/width of the two signals must be correct, as well as the synchronization between them.  It can't just be the frequency or we would have got this working by now.
I'm still not clear how the 1:100 frequency ratio comes into play, but I have a hunch if you get other factors aligned, it will make sense.
Tomtech29
another very interesting effect is the reverse direction of the wave to see Tesla 1:25
https://www.youtube.com/watch?v=NVUgZAa1CvM
the probe is away from the antenna so reverses the magnetic field in the inductor truth ?
Tomtech29
Hi.All
I would like to present to you my idea:https://www.youtube.com/watch?v=EJyKjtSdjYI
Alternatively, the PLL but it should work in a way maintaining resonance in the saddle and ride forward :D
NickZ
  Tomtech:
   That's interesting. But, your bulbs are still not bright, at all, even with the extra coil connected.
   But, maybe you have something there.
   Were you running those bulbs just from the 3 turns coil's output at the grenade 168t coil?
