0 Members and 52 Guests are viewing this topic.
NickZ
Quote from: Dog-One on January 25, 2016, 09:37:55 AM
@NickZ
I think you're mostly correct, but I must add:  I think the pulse shape/width of the two signals must be correct, as well as the synchronization between them.  It can't just be the frequency or we would have got this working by now.
I'm still not clear how the 1:100 frequency ratio comes into play, but I have a hunch if you get other factors aligned, it will make sense.
   Dog, the earlier Ruslan videos were showing a regular sine wave signal from the Kacher circuit, nothing out of the ordinary.
And the device still would self run.
    I'm trying to replicate THAT effect, if possible.
   Itsu:  You mentioned that the Kacher can not be controlled by a TL494 circuit, or a PWM.
Would that still the be case if just using a PWM (simple 555 circuit), onto the Kacher?
  It's interesting what Geo mentioned, that if he raises the duty cycle over 30%, it stops oscillating.
At least that's how I understand it.
  Maybe that's why I don't get any interaction, when using 100% duty cycle.  Or not?
  Shortening the duty cycle reshapes the wave form, to produce a higher more pointed peak.  Right?
Tomtech29
Quote from: NickZ on January 25, 2016, 01:02:34 PM
  Tomtech:
   That's interesting. But, your bulbs are still not bright, at all, even with the extra coil connected.
   But, maybe you have something there.
   Were you running those bulbs just from the 3 turns coil's output at the grenade 168t coil?
It is important to keep current in the circuit in series Lc the rest take care of Tesla!
See how he does it,still a long way to reach the 1260 Watt but it must be done.I do not have such a PLL
I would try to bring about this effect it's possible the right way?
because it interesting that the sources amperage little changed from another bulb!
Now I wonder what he's doing winding 28 which do not have!
NickZ
  Yet, it looks like the scope is showing a frequency change with every additional bulb that Ruslan is lighting.  But,  he's showing that he can bring it back to his best frequency point, again.  Or is this happening on it's own?  As I can not see what he's doing.
starcruiser
Quote from: John.K1 on January 22, 2016, 04:22:47 PM
Thanks Geo. It looks like we are on the same wave :D   Now the question is how to create that uni-polar pulses. My guess is they are formed on the  ferite rod between the Tesla and antenna. My previous experiment some time back was unfortunately  unsuccessful ;( Any idea?  I can get them easily on the toroid with two coils.
Look a the Ferrite rod, the 2 coils, one is 4 winds and the other 5? they are opposing thus cancel except for one direction???? a strange Diode of sorts perhaps? Just a thought
Regards,
Carl
Tomtech29
Quote from: NickZ on January 25, 2016, 02:57:39 PM
the push-pull system works like that to tune up when the load does not increase the current drawn from the battery but falls 800mA max incomprehensible.
connect the circuit 28 turnover reflects on a large consumption of energy with battery and if you use only 3 turnovers There is not enough power to light 300 Watt.
so in my case
(Now he has a combustible yoke of plutonium) nuclear reactor or at Hee haa
