0 Members and 151 Guests are viewing this topic.
NickZ
  Would be a little easier to see the similarities if I could understand what he was saying about the Hendershot diagram. How 'bout a hand?
  So, is the choke inside the akula device's big secondary coil, connected only to a cap, and nothing else?  Seams like it could have the same function as the Dally coax cable that is shorted at the end. Yes, No? Maybe?
NickZ
  @ MenofFather and All:
    I'm starting to understand the akula hand drawn diagram as well as his circuit a bit better now.
    I see that the yoke is first wound with 12+12 turns and is center tapped. The white 3 turns wire on the same yoke goes to the big AC (5 micro farad?) cap, which then continues to a 7 turns coil wound on the big air coil tube, but is Not connected to anything there, just returns back to the yoke, to close that circuit.
The choke is also a separate circuit, and not connected to anything other than a cap, of unknown specs. Output from the big air coil white wire secondary coil to lamps is 400v.
   I want to focus on the circuit without getting into the pulse driver. So, for now I'll just pulse it with a single TIP 3055 transistor ferrite rod set up ( Lasersaber 3.0 circuit)  that I already had shown previously, and a 12v 500mA wall adapter, right to the center tap of the yoke.
  The battery/inverter/rectifier, will have to wait until I have this working first (or not), without the feed back path.
  Back to my studies...
Void
Quote from: NickZ on May 01, 2013, 02:21:24 PM
Hi Nick. Your guess is as good as anyone else's, considering that no one seems to know much detail about the actual coil assembly for sure, except for the person who built it. If the device is not faked and actually does self run (again anyone's guess :) ) it will likely still be hard to replicate without knowing most of the details about the coil assembly. If the hand drawn schematic is fairly accurate for the akula device, then maybe there is a chance to replicate, but there is no way of knowing if the schematic is even accurate. The actual device may be using a different type of coil arrangement. Not trying to discourage anyone, but that is the reality. Unless Akula comes forward with more specific details on the coil assembly (not likely going to happen in my opinion), then it is just likely going to be a lot of trial and error, with emphasis on the error part. :) At any rate, there are a few frames in the Akula video that show a close up (unfortunately fairly blurry due to the low resolution video) of the inside of the coil assembly. Looks like the so called choke coil is sitting on some sort of cylindrical shaped object, which might be just a plastic or other material cylinder used to position the height of the choke, or it might be a metal can type capacitor or even possibly a home made capacitor. It also looks like there may be some sort of lining on the inside of the coil form such as possibly aluminum, but it might not be lining at all and it might be just some overlapped tape at the top of the inside of the coil form tube which makes it look like there might possibly be some lining there. I have attached a screen shot of this, but it is kind of blurry. Hard to make out details for certain.
Ganzha
Quote from: T-1000 on May 01, 2013, 12:11:46 PM
http://www.youtube.com/watch?v=kNp-Q1B6KkY - please see where Romanov points mouse and follows circuit. See similarity to latest devices here? ;)
Explanation of Romanoff is not obvious, point of  mous is not visible, i am not trust such explanation because Romanoff not did clone of Lestor Hendershot Mark 2 generator yet.
These explanation just his (Romaniff) own fantasys. :(
NickZ
  @ Void:
   Thanks for your comment, as well for as the picture of the inside of the air core coil. There is something in there alright, but it looks more like plastic than aluminum.
Hoppy will probably take a look at it, and let us know what he thinks it is.
In any case I'll try to put some Aluminum in there, if I can't get it to do what it's supposed to, without it. Maybe an empty beer can, as I seam to have no shortage of those, lately. But, I may be able to do better than that.
  The diagram is also looking better and better as I study it more, and take my time about all this. I still can't make out if the red windings on the yoke are connected to anything, or not, as it looks like the right side goes to the big cap, but it may not. They are probably not going anywhere, if they are maybe Hoppy can tell better than me.
  @ Ganzha:  I have to agree with you, plus Romanov is not showing a self runner, such as Hendershot was. And his 3.25 amp input to a light a single bulb on one of his circuits, also makes me wonder, as it doesn't look like the 500 watt bulb, that akula used.
  I'm glad to see the Russian guys giving us a hand here, also. Much appreciated!
  It's really the self runners that I'm mostly interested in, although an efficient high output power circuit should not be taken lightly, either.
           NickZ
