0 Members and 68 Guests are viewing this topic.
Dog-One
NickZ
Dog-One
I see in this Saeed schematic, reference to 17-27-37 again.
Anyone have a clue what that means?
magpwr
hi everyone,
I was about to assemble a prototype which was already tested on breadboard which is one of a kind PWM generator which works from low voltage all way to high voltage.
This design is 6 times better than the Russian favorite TL494,lowest component count and good for anyone with just soldering iron skill at least.
This circuit is tested to work from 9volts onwards and able to work with low 12volts to high voltage 350volts dc (Full bridge-rectified from pure 12-220v inverter).
But wait a second
As usual i am hit with sudden in rush of ideas after digging up old archive from Akula . (Distracted in a good way i think) :D
If anyone recall in sergey circuit the kacher portion is operated using interrupter pulse with the additional ability to position the stream of pulse.
The Akula circuit should be generating low frequency "interrupted" pulse" since the transistor already is oscillating at whatever the natural frequency of Tesla coil.1.7Mhz...1.8Mhz.
Kacher circuit of  Sergey is operating near 100volts by looking at the capacitor rated value and Akula is using high voltage anywhere from 100volts...200volts.
PWM circuit of Akula and Sergey is completely different.
PWM circuit of Akula is highly likely running at "1/2" the frequency of the detected frequency(Eg:1/2 of 37khz is 18.5khz for pwm).Since we should still remeber that Akula did mention for Air coil it should no go below 17khz in order to maintain a certain level of efficiency.
LM393 merely amplify signal from current sensor toroid and convert it to logic.
CD4017 -Divide by 10 .This i/c is likely configured/connected as divide by 2 instead.
IR2111 merely split the signal in this circuit of Akula.
IR2113 is the IGBT or Mosfet driver.
PWM circuit along yoke of Akula is driven using 24volts.Take note of the operating voltage limit of IR211x which is likely regulated at 15volts  to 18volts.
NTC1 in circuit of Akula is likely a varistor around 100volts to Earth.
This is the most obvious circuit pwm circuit of Akula's which wasn't replicated by anyone to date.
After watching Vasmus video with use of nano-crystalline core merely for efficiency.I am now confident to say it isn't ferrite or Rubin ferrite yoke that produce this OU.
This should be considered good news for the 99% of the replicators. :D :D :D
Latest update-The LM393 input might be likely coupled together with some kind of low pass filter to accept sub-harmonics of below 45khz or band pass filter to accept around 17khz....37khz for sub-harmonics.
That is how crazy it is. :D :D :D
That's all.
NickZ
   Dog One:
   The 17, 27, 37 refers  to the running frequency in kHz, of the 3 turns coil, as read at the tuning capacitor using a scope.
   17kHz, 27kHz, 37kHz.
   Those were the same frequencies as what Akula's diagram suggested to be the right resonant peaks to tune to.
