0 Members and 114 Guests are viewing this topic.
x_name41
some powerfull versions of the Ruslan Kulabuhov deviice
John.K1
Ok. For Nick and other who couldn't play video straight from DropBox, here is the zip for download: https://dl.dropboxusercontent.com/u/61581587/HowIsItWorking.zip
Tomtech29
x_name41
Thanks for the scheme, most of these oscillators already have,interesting solution is the pulsar to the board!(pulse packet)
-Also useful is a machine with relays.
:D
Tomtech29
Quote from: magpwr on January 27, 2016, 09:42:47 AM
hi Tomtech29,
I have assembled a even more simple circuit today on breadboard using only 2 i/c instead of 4 to achieve the same thing which produce 1/2 the input frequency base on test.37khz in and produce 18.49999khz pwm output.
UC3825 apart from usual (+) (-) inputs and  the usual1.5Amps rated dual pwm output compared to lousy TL494 250mA output,6x better.
The pin 5 of UC3825 connected to pin 16.Pin 6&7 is connected together and this become the clock/signal input.
All the other pin is untouched.But i did implement soft start(3s delay start after power on) by placing 10uf capacitor at pin 8."Optional just to prevent sudden rush of current by protecting mosfet or igbt ,1.2kv rated."
My only LM393 was damaged so i am using a TLC272 which eventually needs to be connected to the toroid,so called current sensor toroid.
The input stage it's still a work in progress. :)
That's all for today.Got to rest. 8)
I do own a usb spectrum analyzer it really does produce sub-harmonics in khz  if i apply sweep frequency from 1.65Mhz to 1.8Mhz on the kapanadze winding.
This was the important test i need to do before even deciding to commence on the above experiment. :)
I'm curious about your work and especially this circuit LM I found a diagram ,
I do not have a replacement for the :K55TB9
what to put there?
These ICs probably would have found: 74HC14,CD4046,LM393,IR211?
You say you moved simulations Is it possible to check how stabilizes the frequency of Lc?
it would be great if you could say something about this scheme.
T-1000
