0 Members and 399 Guests are viewing this topic.
GeoFusion
Hoppy,
Brilliant so you also witnessed it  ;D, awesome.
Yes continue on it Hoppy, I think that is where we need to go to finish this device! :)
Yes I will try to do what you asked. sure thing.
Well I will see what can shield it on side,... not sure sins radiant passes thru everything thru my experiences
This device has some odd yet amazing potential!
AlienGrey
Geo Hi it lookes good  but won't they need all the info on how to wind the big plastic tube coil like turns and wire size  katcher winding info ect if you could divolge that info it would be great, many thanks  AG
Hoppy
A quick scan of the Sergey schematic posted by Geo earlier shows a couple of naughties. Namely the DC block on the supply to the Kacher primary and the 100 mA fuse in the dotted supply line to the push-pull and control circuitry.
T-1000
Quote from: Dog-One on January 28, 2016, 05:55:40 AM
@T-1000
Have you made an attempt to contact Sergey?
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg471665/#msg471665
I'm curious if he could offer any tuning steps or situations that can be identified early when the device cannot work as configured.
Hi Matt,
I took my time to download torrent and watch Sergey videos. They seem quite good for ones who are trying to replicate Kapanadze style device as there is his own interpretation and short video of possible self runner as well.
To break down his circuit, there are few his own moments:
1) He did not use katcher circuit. The nanosecond pulse generator with variable delay line produced pulses for the Tesla coil. He used up to 7 pulses per ON/OFF cycle.
2) The power line for the Tesla coil driver came directly from the toroidal transformer used after push-pull (he did not use yoke nor flyback transformer core). Which relates also directly what URFA's version of the current transformer does for a sync of pulses between inverter and the Tesla coil. http://i.imgur.com/2AeMUl1.jpg
3) He used aluminum foil layer with slit in grenade coil underneath the half-length layer for the better static coupling inside of standing wave and attached to "hot" end of grenade coil.
4) The windings of inductor and grenade coil are in opposite directions. His reasoning for that was about better mixing of current in earth side of coil with voltage on opposite side. And the wire lengths for grenade coil/inductor are 1/2 of grenade coil wire length.
5) The wire for starting layer in his version of first half of grenade coil was coming from full length layer end to the middle of it.
I have him in skype contacts but he's seen rarely there due his living remote location somewhere in the mountains.
Cheers!
x_name41
