0 Members and 149 Guests are viewing this topic.
Hoppy
Quote from: NickZ on January 31, 2016, 12:07:26 PM
   If your HV device does not brighten the bulbs and output considerably, you won't have a chance at free running.
   That is not just a detail.  It's an very important point that is being underestimated. But, is only one of the first steps of our goal.
   No use trying to make a device self run, or to do any measurements, when there is no real interactions going on, yet.
   But,  It will come...
That's a set of bold statements Nick! Its nice to know that I'm at least part way there then.  :)
NickZ
   Hoppy:
   As there seam to be more than one way to get these devices to operate, now I'm trying to observe the effect by just connecting the 3 turns coil/cap/induction coil, and Kacher, without the 28 turns coils connected, and no Mazilli. And to try to replicate my own previous lighting of a 50w and 25w bulbs from just the Kacher's output, as seen at the end of 168 turns coil.
   My Mazilli is still not working, and I'll need to order some more parts to continue with it. Or to find another solution, instead.
   I do agree with you, that you were close...  and just one connection that is not allowing the full effect to come through, like using less than optimal bridge rectifier diodes, and capacitors), may have been your only hang up back then
  So, play it again, Sam.
Void
Quote from: Jeg on January 31, 2016, 02:50:40 AM
Always good to read you Void! Hope everything is fine!:)
Hi Jeg. Nice to see lots of the same people still around in this thread. :)
All is OK here. I have been busy the last while so I only check in here once
in a while when I get the chance.
Jeg
Quote from: NickZ on January 31, 2016, 10:14:18 AM
  And, quit knocking whatever anyone comes up with, while you personally come up with nothing to show. And are just there criticizing.
Hi Nick
Talking about electronics, and most of important sharing experience, is not criticism. You don't need a fully working device to understand that Current meters are vital when you experiment.
Jeg
Quote from: John.K1 on January 31, 2016, 10:55:09 AM
I need to understand why has Ruslan last part of his Tesla coil in opposite direction and possibly bigger diameter of wire?
It is difficult to be in Ruslan's head but hopefully we know what this can produce. Two things.
1) It raises the output current of HF before going to the antenna,
2) It lowers down the magnetic interaction between katcher's main body and grenade as they are the one very close to the other at the same axis. And so the main interaction happens only between antenna and grenade.
