0 Members and 101 Guests are viewing this topic.
John.K1
Quote from: Jeg on February 01, 2016, 02:16:23 AM
It is difficult to be in Ruslan's head but hopefully we know what this can produce. Two things.
1) It raises the output current of HF before going to the antenna,
2) It lowers down the magnetic interaction between katcher's main body and grenade as they are the one very close to the other at the same axis. And so the main interaction happens only between antenna and grenade.
Hi Jeg.
I was trying it myself yesterday to see the effects with different configuration of winding. First I checked the resonance of the normal coil. Than I wound 1/4 in opposite direction and then I tried to rewind coil each 1/3 in opposite direction.    The one with the 1/4 in opposite direction gave me higher resonance frequency( rise from 6.09MHz to 9Mhz) and higher Vpp (from 6V to 10V). Three section coil each in opposite direction has also high frequency(10MHz) but lower Vpp and it has also longer dumping effect  (the wave is more uniform)     This is just a basic test. More tests will follow.  For test I just trigger the 3 turns of primary with charged cap (5V, 6.2nF) and the main probe is connected over wire's insulation and each test has been performed 6-8x.
Jeg
Quote from: John.K1 on February 01, 2016, 03:18:41 AM
Hi Jeg.
Great result Jan. I will use it next time for frequency correction. ;)
Hoppy
Quote from: NickZ on January 31, 2016, 05:06:25 PM
   Hoppy:
   As there seam to be more than one way to get these devices to operate, now I'm trying to observe the effect by just connecting the 3 turns coil/cap/induction coil, and Kacher, without the 28 turns coils connected, and no Mazilli. And to try to replicate my own previous lighting of a 50w and 25w bulbs from just the Kacher's output, as seen at the end of 168 turns coil.
   My Mazilli is still not working, and I'll need to order some more parts to continue with it. Or to find another solution, instead.
   I do agree with you, that you were close...  and just one connection that is not allowing the full effect to come through, like using less than optimal bridge rectifier diodes, and capacitors), may have been your only hang up back then
  So, play it again, Sam.
Nick,
IMO I did get the full effect by getting very close to blowing a 60W lamp and I could extinguish the bulb just by moving my hand close to the antenna. You can't get a much better effect than that! ;D Seriously though, the important part is understanding the nature of the 'effect' by measurement to see if it reveals any degree of power amplification. My conclusion from measurement and knowledge of electrical principles, was that the 'effect' was not unusual and it did not amplify power, in fact my device was still running well underunity.
You are in a good position to now ditch the Mazilli and replace with a PWM push-pull. This will allow you to more closely replicate Ruslan's, Akula's and Sergey's etc. devices.
T-1000
Quote from: John.K1 on January 31, 2016, 12:13:41 PM
What o you know about  "Resonance in resonance" - Dividing signal into small parts where mixture of currents and voltage appears ?  ;)
To play Russian?  Nu davaj ;)
It is modulation of resonant signal not division. And the modulated signal is also resonant. The main reason for that is the bringing up current and voltage into same phase (the default resonance is up to 90 degrees).
PS> The Romanov >1h video is too long to translate due nature of him talking about different things there.
Zeitmaschine
Quote from: T-1000 on February 01, 2016, 06:11:34 AM
Yoke doesn't bother meat the moment :)  What o you know about  "Resonance in resonance" - Dividing signal into small parts where mixture of currents and voltage appears ?  ;)
Ever tried experimenting with a simple frequency doubler like Stepanov (see illustration below)?
And yes, the LC series circuit creates a phase shift of 90 degrees in addition to the doubled frequency. Also the resistor (mine is 1800 Ohms / 50 Watts) gets really hot after a few minutes when connected to mains voltage and that reminds me of Kapanadze's heat sinks on the green box which obviously needed a cooling fan.
Just a hint ... :)
