0 Members and 220 Guests are viewing this topic.
dllabarre
Quote from: NickZ on May 01, 2013, 02:21:24 PM
  Would be a little easier to see the similarities if I could understand what he was saying about the Hendershot diagram. How 'bout a hand?
  So, is the choke inside the akula device's big secondary coil, connected only to a cap, and nothing else?  Seams like it could have the same function as the Dally coax cable that is shorted at the end. Yes, No? Maybe?
Akula's device is said to be like Hendershot.  But only one side of Hendershot device, half of Hendershot, only one large coil where Hendershot has 2 large coils.
According to Hendershot schematics and pictures of Hendershot device, inside of large coil is a handmade capacitor connected to a coil and nothing else. Same as Akula shows in the middle of his hand drawn schematic.  A coil and capacitor connected to each other and nothing else. A tank circuit that is tuned to oscillate at a certain frequency.
Hendershot used aluminum sheet inside his coil form also.  He also used aluminum sheets to make his own capacitor that was inside the large coil.
Just do a search on Hendershot.  There's plenty of information on his device.
DonL
MenofFather
There chematic how seems is Akula divece.
MenofFather
Quote from: Void on May 02, 2013, 04:14:07 AM
Hi Nick. If you watch the top of the air core coil assembly closely in the Akula video, you can see in many frames that there is what really appears to be an aluminum sheet wrapped around the outside of the coil form under all the windings. The aluminum sheeting (or some other shiny silver colored metal) is sticking out at the top of the coil form. The aluminum sheeting appears to be possibly folded over the top of the coil form at the top inside edge. This would seem to be at least part of what Akula was referring to in regards to the Hendershot generator, which has the two main coil forms around home made metal cylindrical capacitors.
I have attached some screen shots, but I think it is quite obvious in the Akula video if you watch closely. There appears to be quite a wide gap in the aluminum sheeting at the back side of the coil form of about roughly 2 to 3 inches.
I think in Akula divice maybe no aliuminium sheet, this maybe be isolation who looks like aliuminium.
MenofFather
I calculate red inductor wndings in air tube, it have 12 windings.
MenofFather
White wire, who gose to lamps seems must have about 40 windings.
