0 Members and 414 Guests are viewing this topic.
NickZ
  Were the first few videos shown by Ruslan uni-polar devices?  Or, were they just ordinary Kacher circuits, single pulse, regular sine wave type devices?
  John K1:  Thanks for the info concerning the reason that Ruslan took all his YouTube videos off...  I had thought so, as well.
verpies
Quote from: NickZ on February 02, 2016, 09:14:36 AM
Verpies:  You are mentioning that Itsu's SG can inject a proper signal,
Except for the amplitude - yes.
His SG can generate a signal of an arbitrary amplitude with an amplifier, which I have mentioned in my previous post.
...comparable to what the yoke/grenade circuit can produce???
In your question you assume that the yoke/grenade is "producing"?  Are you sure yoke/grenade is "producing" something and is not merely being subjected to the aforementioned externally-generated signal?  That's the difference between donor and acceptor.
T-1000
Quote from: Hoppy on February 02, 2016, 10:12:16 AM
Sorry T1000 but you posted the same video some time back and this one is also inconclusive and incomplete in necessary build detail. The effect shown is likely just an impedance matching issue. We need to see a much better conducted and presented video. I'm getting tired of seeing these half-cocked videos claiming to show something unusual going on.
Instead of complaining you could just build this simple 50Hz inverter circuit on solenoid core made from stacked ferrite rings. Then repeat experiment and do all measurements you need if you can get same effect.
    T-1000:
   If that system was self running, he would have shown it doing so. Not just barely lighting the small microwave bulb.
  You can see the amp meter jump to about 4 amps when he turns it on. And then it drops back 0 amps, when just barely lighting the bulb, and showing no draw.
  A bit strange, and hard to judge just what is happening there, but we can see that the bulb is very dim when there is no draw.
So, there is probably little actual effect from that Kacher circuit, at 0 amp draw. Or not?
  Those are my impressions, without understanding what the guy is saying.
Why you would shoot high while you still need a method for know-how doing it?
All I wanted to show - there is possibility to light up bulbs brighter while consumed power drops after introducing secondary signal into wave mixing. And it is not on expense of the power source.
Void
Ok, I have been catching up on Akula's latest videos.
Interesting that he says that he believes that all his devices work on the same principle, even though he has
built a wide variety of devices in the last couple of years. Akula said he thinks it is all the same principle whether
it is applied to his low power LED devices or his high output power devices. Akula's basic 'schematic' shown in his video
posted Sept 7, 2015 of the basic core circuit configuration which he believes is common to all his devices is interesting as well.
If this information posted by Akula is basically correct, then it seems to me we still need to figure out one or more missing
key pieces of information in regards to this. I think it should not be surprising that Akula would leave out one or more
important details, as Akula is trying to market his devices commercially.
So in view of the above, I have been considering what might be a missing key ingredient or missing ingredients, and I am planning
to conduct a few experiments along this line to try to dig into this aspect a little further. Thanks to Wesley's recent posting
of a video which summarizes the second 'Lithuania Experiment' by Wesley and T-1000, and others, I plan to try to replicate what
was done in that experiment to see if I can find a magic 'modulation' frequency which causes the system to start producing unusual results.
One hypothesis I am considering is that in the Akula/Ruslan device which people have been trying to replicate here, the tesla coil
frequency may possibly be as important as the phase timing of that signal, depending on the exact circuit arrangement being used.
So, if there is a critical magic frequency that must be found to kick in the overunity effect, then my doing some experiments to
try to replicate the Lithuania experiment # 2 using the ferrite TV yoke, to see if I can find such a magic frequency for the ferrite TV yoke
I have, might be worthwhile.
T-1000, would you be willing to answer a few questions I have on this experiment that you participated in using the TV yoke,
if I post my own experiment results back here? I believe I currently already have all the necessary components and measurement
equipment I will need to try to replicate what Wesley reviews in his recent video. I have suitable signal generators as well as a 100 MHz
oscilloscope which is capable of also acting as a basic spectrum analyzer as well. In conducting some related experiments a while
back, I did notice that one problem I will have to work around is that local AM broadcast radio stations in the Medium Wave band
(about 530 kHz to 1.7 MHz) can show up as blips on my spectrum analyzer when monitoring a coil of wire on a ferrite core. Hopefully the
magic frequency of my ferrite TV yoke core and windings won't be right close to a frequency of a strong local AM broadcast station. :)
By the way, in Wesley's recent video he states that the Russian ferrite yoke core they used had the markings: OC-90.38nu12
One of my (Russian) TV ferrite yoke cores has the markings: OC-90.29nu10, although I have no idea what those markings indicate.
Anyone know what those markings indicate?
My ferrite yoke core has the following dimensions:
Wide opening outside diameter: about 105 mm, or 4.3 inches
Narrow opening outside diameter: about 65 mm, or 2.5 inches
All the best...
Void
Quote from: NickZ on February 02, 2016, 01:29:19 PM
I seemed to have missed that. What was the reason?
