0 Members and 28 Guests are viewing this topic.
Void
Quote from: Jeg on February 02, 2016, 03:26:07 PM
I hope you are right as I have a nice power amplifier. I will calculate the impedance of my primaries to check it. Thanks :)
Hi Jeg. The input impedance of the primary winding on the ferrite yoke core won't exactly be the
inductive reactance of the primary winding alone at around 15 or 20 kHz. The yoke core itself will
transform the impedance of the secondary winding and the associated circuitry it is connected to back
to the primary winding when the circuit is all connected together and operating. When you have the circuit all connected together,
you may need to experiment a bit with the number of windings on the primary winding to give the best performance,
and which causes the least amount of heating on the output transistors of the audio power amplifier at a given
power level.  I would suggest running the power amplifier at lower power levels first and making some adjustments to
the primary windings to try to tune things up better, before turning up to higher power levels.  Keeping a close eye on how hot
the final power transistors are getting on the power amplifier when testing with it is probably not a bad idea... :)
John.K1
Quote from: NickZ on February 02, 2016, 02:29:25 PM
    Verpies:
   Well, I haven't seen my yoke generating or "producing"anything other than what it gets just from input signal. No additional power coming into it from the ambient observed, as yet. Nor a reduction of the input power, at any point. Which is what I've been looking for.  If that's what you were asking.
   A signal generator's amplitude, and current levels can be amplified similar to what the push-pull circuit can produce?
That's interesting, and I'd like to see that.
  How or why is that any different from what the TL494 boards are already doing, when controlling the frequency and duty cycle?
  Forest:  That's no yoke...
   John K1: You want to tell them what they may have missed, before the deletion?  I can't.  As it was removed it, for a reason.
What the F... I deleted the post because my fingers were faster than my brain :)  Anyway - Why Ruslan deleted his videos?  There might be more reasons why .  In one of his last videos he complains about the comments and how he is sick to read them (actually he didn't read them) - in other word - he got pissed off, He also was saying something there is some people who doesn't like it and that is why he is not gonna show it all ( it just sound like he was threatened - just a my personal feeling and conspiracy  :)
Romanov said he tunes the device to the frequency of earth in given territory. He showed how to make such resonator and there is also other guy who shows the same think with two coils and magnet and transistor. I got today coils (relays) from Russia- the same ones like in the movie and now working on it. And may be I will implement it in to the Ruslan's device.  Than I will be tuned to the local ground :)
Void
Quote from: John.K1 on February 02, 2016, 03:48:00 PM
Hi John.k1. That's another avenue to pursue in regards to trying to unlock the 'secret'
of these devices. One thing to consider is that Akula showed in his second high power self runner
video that he could disconnect the earth ground wire and it continued to self run, although with less
output power. To me, that seems to indicate that what creates the over unity effect is not the connection
to earth ground itself, but an earth ground connection seems to boost output power a fair bit. Also Akula's
low power devices do not seem to use any earth ground connection, if you allow for the possibility that his low
power devices are not fakes. This is leading me personally to look for the core part that causes the actual
over unity effect, but your approach on trying to tune for a suitable earth ground frequency might prove very
interesting as well... Between the two different approaches we may come up with something useful... :D
Void
HI Nick. Yes, there is no no question in my mind that ferrites can be a real yoke... :)
John.K1
Quote from: Void on February 02, 2016, 04:00:53 PM
Hi Void,  Don't forget Akulas's device stopped working in Germany. Also something to consider what Romanov shows again in his movie I posted earlier  - Magnetic field of earth is more complex. Romanov actually compare it with the sun, where you can see the eruptions. Something similar is on the earth.  It is not just only north and south pole between which are flux, bu there is several (or a lot of) some small local ones too. Which reminds me I was actually watching some document about the same short time ago.  I just want to say you might be lucky and be in energized place or you you have just bad luck :) Remember document about Don Smith, with some Geo whatever Map on his table?
