0 Members and 66 Guests are viewing this topic.
GeoFusion
   Nickz,
My fets and circuit can handle the power lvls when it works but, as I witnessed it,but I should never remove ground when on high loading.
Yes you will need the TL494 or some good PWM to put it to the test :),
Btw on your setup in video, try to light that small bulb on one end of the grenade and one end to earth ground
see if it lights up with kacher on.
Not sure if you have tried it already.
Btw the mediator nick, word of advice, it's better using larger toroids then small ones which we use for chokes / inductor for mazilli.
All/.
Btw what I wanted to point out again is when tuning the duty cycle when almost reaching 30%
you would hear some distortion noise coming out of the mediator or ferrite ring/yoke. just like radio.
( You'll see like it almost kills the load completely) but only then the URFA Effect comes in play. :) ground must be connected!
When Tesla coil  turns on, It enables the effect to happen where Tesla coil is sensitive and further tuning with freq adjusting
for resonance and better output :). It seems like it activates the Aether/Radiant energy around us to be ready for use.
On my circuit it's very delicate tuning while finding the correct setting to find the URFA effect style.
but when having it working is awesome action.
This can be Different on any Pushpull board, so I won't know for now until someone els does it also or my self
with other boards for the tests.
Can't wait until to do further experimentation on this!!!
I will take a look at the pushpull circuit today see if it is fixable.
      Cheerz~
Void
Quote from: T-1000 on February 04, 2016, 02:35:36 PM
I just replied in http://overunity.com/4333/meyer-mace-isotopic-nmr-generator/msg473160/#msg473160
I think that thread is more appropriate for that discussion so we can keep Dally thread clean from mixed topics.
P.S. You may read entire thread there.
Cheers!
Thanks T-1000. I have a feeling that it may at least possibly all tie together, as NMR as a possible explanation is
not really established at all at this point I don't think, although there may be something to that. Since Akula
has apparently done similar things with different configurations, for me anyway, whatever it is that is (apparently) being tapped
into is still a question mark at this point, and there may possibly be various different configurations that can tap into it.
Quote from: verpies on February 04, 2016, 03:13:17 PM
As far as I remember they did blow it up and there was a long pause in their experiments while they were getting a replacement.ers
I distinctly remember 2 layers.
Hi Verpies. Ok on that.
@GeoFusion, unless you are powering from batteries only, there will always be a big question
mark around any effects you are seeing, due to the circuit having an earth ground connection.
Hoppy
Quote from: Void on February 04, 2016, 03:57:58 PM
This applies equally to NMR experimental devices and test equipment.
Void
Quote from: Hoppy on February 04, 2016, 04:18:35 PM
Yes, there is potential for ground loops to the mains any time there is connection to mains connected test equipment or power supplies or a direct earth ground connection.
NickZ
   Ground loops, huh???
   Here's another short video I just uploaded of Tiger's device, to which I added the audio spectrum analyzer to see his running frequency.
   I thought that on that older Wesley video was also the running of the Lituania device, but, it's not.
So, Tiger's device is what's running on this video.
   https://www.youtube.com/watch?v=R7YCgIsGqVE
