0 Members and 137 Guests are viewing this topic.
NickZ
   Geo:
   You asked if I could light a small bulb off of the ground connection.  I can light a microwave bulb just from the Kacher's output at the end of the 168t coil, with just one side of the bulb connected to the coil, and the other side going to earth ground.
So, the answer is yes, but only up to a 25w bulb. A microwave 220v, 20w bulb works best for me, and will light fairly bright.
  Hoppy: In my case when the yoke goes into the vibrating mode, (like you like) it can indicate that there's to much current running through it. As it takes current to create that strong vibration. HV won't do it. At least not by itself.
Hoppy
Quote from: NickZ on February 05, 2016, 03:40:57 PM
Yes, in order for the bulbs to glow brightly whilst the 'effect' is being observed, then its reasonable to assume that a high current flows from the source supply. This is why its important for Geo to measure when his device is back working.
NickZ
  Yes, but I didn't notice any effect, just the strong current vibrating the core (NMR, oh no!), was just probably caused by a short circuit just before the circuit died.
  Can the 18v zener be replaced by a certain value capacitor, or another type of diode, instead. As I'm out of those zeners, for now.
I think that the fets may be ok.
  Or, maybe I can run the system on my 12v battery, like I did previously, using just the 12v zeners on the Mazilli, until I can order some more parts.
  I'd like to look into the effect that I showed on one of my videos, when lighting the 25w and 50w bulbs, just off of the Kacher circuit output, while running from a 12v, 2.5A wall adapter.
Jeg
Quote from: Hoppy on February 05, 2016, 09:32:45 AM
Jeg,
This was with TVS diode suppression across the main 24V PSU output.
Was it at 30V? Did it suppress High voltage successfully? Sometimes HV strikes me when i touch my metal pots for altering frequency and duty cycle. Even they are grounded!!! So i ordered some tvs at 30V@ 600W
John.K1
Quote from: NickZ on February 04, 2016, 05:36:41 PM
  I notice that when I connect my 100x scope probes to the 168t output coil, it can kill the effect that the Kacher has on it, so I leave the black probe off, disconnected. It's not as accurate a reading that way, but it doesn't kill the effect.
This is why I connect my probe over insulation. Try and see.
