0 Members and 219 Guests are viewing this topic.
NickZ
   Guys:
   Here is a question I asked at Energetic Forum, along with Wesley's reply.
As I feel that it also deserve attention here, as well. As this sister thread also deals with similar topics.
Quote:
  Nick_Z
Senior Member
Wesley:
When do you think that you'll be able to show an ELECTRIC current output from your device, to prove the point of nuclear decay being a useable power source?
   Qoute:
  Not soon.
I do not have proper compound
Copper and Zinc  was delivered to my friend scientist as oxide.
Taking that I can only play with black part of it that is  permanently  embedded in to the total compound.
I have got  yesterday
The scintillator  dual photomultipier. I have redone ribbon cable chewed by mice.- Internal color display does not work. However it work with external  monitor. So far I did not try it with serial port of external computer but software works only with XP and is  password enabled.
I got to wait for powder.
@ glass  pipes got damaged copper is out from  one side- fortunately black  staff  is still intact.
Power amplifier:
I do not have  anything  with high power to try it on range from 100-500 MHz but I'm working on it.
All I have  is 420-460MHz 50W regulated.
Spending is big as well for all of radioactivity based  toys and travel.
But I pay only for my  part. My friend for his.
Eventually  I might be refunded with  it  without restricting conditions by  any means. That is the deal.
I'm not obligated to keep anything secret but 180 degree opposite.
And I operate  by this conditions.
Reasons for time taken?
1.cost
2.lack of experience in this field as no one knows  what that leads to.
3.playing with different substances takes time also getting substances even more.
4. estimating level of "unpleasant factors" and proper safety  measure.
Honestly  I was never trying to build TK but to understand how it works.
Strange as it sounds this is  the way I'm.
Fascination with already  naked woman  is short as than there  is nothing new left.Just action..... there is no process left anymore.Nothing to uncover, nothing more to expose, no new futures, no surprising factors
Yes she might  be  very special .so what... it is like Kapanadze  explained.(http://www.energeticforum.com/images/smilies/smile.gif)
Please understand that
                                            End quote.
   Well, I am trying to understand:
  "Honestly  I was never trying to build TK but to understand how it works.
Strange as it sounds this is  the way I'm."
  As there have been no replications of the Colman patent, at least that I know of, that show proof of a small tube of substance yielding 10 years of electrical output due to nuclear decay.
    Although, I thought the idea was to save to world, revolution, etz....
    Maybe now, I do understand...  and I'm not knocking it. As the Experimentation is a goal in itself.
MenofFather
Seems yelow isolation wire on ferite transformer in akula video have 22 turns (11x2). His say, that this ware is 6 mm2. Red wire on ferite core also have 6 mm2.
NickZ
    Thanks MenofFather.  I still don't know if the red wire on the yoke is actually needed, or not.  Probably best to use it though, as there may be an unknown function to it, also.
   I will start to wind my yoke tonight, and connect to my single transistor pulse circuit.
What is the micro farad specs on the two AC capacitors?  How many turns on the big air core do you guess there are?  I would think that the cap that is connected in series with the choke is small and inside the bottom of the air coil tube, possibly.  Many unknown questions.
MenofFather
Quote from: NickZ on May 04, 2013, 02:43:09 PM
"What is the micro farad specs on the two AC capacitors?"
Who conected betwen one wire of yoke and air core inductor one wire end, it can be about 400 volts and 50 mikrofarads. The other is like filter parallel to diode bridge plius and minus, it about 400 volts and 100 mikrofarads looks, but it is not important, more mikrofarads is better, highter voltage also is little better.
"How many turns on the big air core do you guess there are?"
About 40-50 turns.
Void
@Nick. If you watch the akula video really closely, it looks like the two red wires from the yoke might possibly be connected in. It is hard to tell for certain though. When I watch that area in the video, I see a few wires in that area that look like they may be connected to the red wires, but it may just be wires that pass close by. Also, if you look closely there seems to be a few unexplained extra smaller wires running around the board which I can't see any obvious purpose for. I am not suggesting hidden power source wires here, I just mean smaller wires that seem to have no obvious purpose that I can figure out. Did you see my post that shows the pictures of what looks a lot like aluminum sheet wrapped around the outside of the coil form pipe?
