0 Members and 60 Guests are viewing this topic.
Void
Quote from: MenofFather on May 02, 2013, 04:51:21 AM
I think in Akula divice maybe no aliuminium sheet, this maybe be isolation who looks like aliuminium.
@MenofFather. That doesn't make any sense to me. It definitely appears to be aluminum or some other shiny metal sheeting, and it clearly sticks out above the top of the plastic pipe used for the coil form. How far this metal sheeting goes down the plastic pipe is not possible to say however since the coil windings are wound over top of the metal sheeting.
NickZ
  I had thought that the red wire coming out of the yoke's right side was connected to the biggest cap that is just to the right of it, but when he knocks over that cap I can't see any red wire connected onto it. The other end of the red wire on the other side may be connected to a white wire, but again, just can't see it well enough. After more consideration, both ends may not be connected at all. This may seem like a small matter, but who knows. Yes, there are extra wires, running by there also, as well as by where the battery is sitting.
  The big air coil looks to be about 2.5 inches wide, or so. It is shorter and wider that the tall white wire wound air coil he shows in the previous video that I just gave the link to yesterday.
  Any way, I'll get a start on it and see what happens, I'm still needing the AC caps though, but I'll see what I can do. I found some aluminum sheet to use for the choke area, but, still looking for my 1 1/14 inch aluminum tubing, that must be around somewhere.
  I like the idea of using incandescent bulbs on this device, as I can't really stand the CFL or LED bulb's light.
   MenofFather:  How does the diagram in the video that I just gave the link to compare to your diagram?
Void
MenofFather
Quote from: NickZ on May 04, 2013, 06:42:03 PM
Diagram in video have some incorects. May diagram looks coresct, but only I also not known where going red wire on yoke. Can go from inverter 220 volts to red wire AC current. To white wire in yoke go 220 DC curent who is mudulatet with mosfet with hight frenquency. To generator hight frenquency gose 12 volts. From invertor DC curent not have smooting capasitor, so it is modulated maybe other need say, but I don't know how. Bigger capasitor is smooth capasitor who conected in parallel to input invertor, it smooths pulsed DC curent after bridge rectifer to smoth DC rurent. Bridge rectifer conected to yelow windings on air core. It (bridge rectifer) is AC to DC 50 herc (akula say low frenquency, so I guest it is desinged in many cases for 50 herc), 50 amps like say Akula.
T-1000
I will put a bit more oil into fire :)
Do you guys remember Delamorto experiment? http://www.youtube.com/watch?v=3ZN1zFzgQkk (found a copy there) and http://www.youtube.com/watch?v=94yCfy8z4lc
Now apply resonance in series+resonance on paralel in that circuit and what do you have...?  ;D
