0 Members and 111 Guests are viewing this topic.
Hoppy
Quote from: NickZ on February 09, 2016, 12:41:18 AM
  PS. As you may know, I don't understand Russian videos, however, I'm trying to explain it the way I see it.
Could be wrong. If so please add to, correct, etz...
Nick,
As far as trying to explain Russian videos, none of us on this forum are in a position to guide or correct you / others on how these devices should work as claimed. The only way forward is for you to bite the bullet and start building your own more sophisticated electronic circuits, like PWM and PLL. More importantly you need to start learning more about basic electrical principles, as this is to an extent preventing you from correctly interpreting what you are observing.
Like Itsu, I don't see anything magic about Ruslan's setup, at least not from watching most of his videos, which is why I'm no longer spending time experimenting with Akula and Ruslan circuits at the bench. That's not to say that I will not start again if I see something that catches my imagination.
Dog-One
Quote from: Jeg on February 09, 2016, 06:20:43 AM
Guys i can not find a proper mosfet driver for finishing my blue box construction. UCC27321 is very rear for me to find in my location. It is not easy to find other mosfet driver with TTL-/CMOS-Compatible Inputs Independent of DC/DC Converters Supply Voltage. I had used mcp1407 which is also ttl cmos input compatible, but NOT independent of supply voltage. Its dc pwr voltage input, has to be the same level with the driving pulse. If driving pulse is at 5v and mcp1407 is driven with 12V then there is a rising internal heat which apparently leads to component damage. Is there any idea for other driver? Do you find it a good idea to drive 74ch132 output to a transistor for making it at 12V?
http://www.ti.com/lit/ds/symlink/ucc37321.pdf
Jeg,
I have never had a problem with this IXYS driver--CMOS/TTL input and 15 volt gate drive supply.  If you want to push it into the MHz range, get the TO-220-5 version and add a heatsink.  I've driven high amp MOSFETs or IGBTs with no issue.
verpies
What about the UCC27511 MOSFET Driver ?
It has 1.2V / 2.2V input threshold voltage that is TTL/CMOS-Compatible and independent of supply voltage up to 20V.
Also, its inputs are universal: inverting and non-inverting, which is important because non-inverting drivers do not work in all applications and in such cases a sister part with inverting input needs to be bought.
AlienGrey
Quote from: Jeg on February 09, 2016, 04:54:22 AM
I tried it my friend. With my fg connected the way we had discussed again (red to katcher's antenna, black to grenade's ground), any sub harmonic frequency lower than this, is more than attenuated compare to 6MHz.
Aint it suppose to be 1/4 wave and that Atom chap was on about 5th harmonic if you recall his comments with DOG, just an idea.
ALSO WATCH THIS ALL THREE OF THEM !!!!!!!!
https://www.youtube.com/watch?v=QDRaCTVO67w
https://www.youtube.com/watch?v=FLirOvTSLYA
Jeg
Thanks Verpies, D1. I just asked my supplier about both drivers and i have also to wait for 2 weeks like the ucc37321 one. As it seems i can not avoid waiting. It's killing me!!!
AG, thanks for the videos i will look at them later and comment.
