0 Members and 250 Guests are viewing this topic.
NickZ
  Itsu and Hoppy:
  As mentioned, I will be ordering parts, but only when I have the full component parts list, and exact diagram to follow.
  Bite the bullet is what I have been doing, already. I'll try to uncomplicate things, when I see what really works.
  The main thing that is holding most everyone up, is that none of the circuits shown, or ideas shared have led to a self runner.
  So, which one to follow, down the same road leading to magic-less drivers, or weak running and inefficient devices.
  I'm still waiting to see what Geo has come up with, as he at least was showing the "effect" to a much higher degree, than I could.
What makes me hesitant still is the fact that the other guys like Ursa, Ypok, etz... have not been able to provide for anything more that just showing the "effect",  after more than a year or so.
Hoppy
Quote from: NickZ on February 09, 2016, 08:59:09 AM
  Itsu and Hoppy:
  So, which one to follow, down the same road leading to magic-less drivers.
Nick,
There is no sense in experimenting with circuits that you firmly believe have failed. Go your own way by first understanding the basics and then by learning to construct your own circuit modules. As you progress learning, you will be able to take other peoples circuit elements and use them in your own designs. You are not going to get a detailed Janet & John guide to designing and constructing a self-runner. In fact you are most unlikely IMO to ever construct a genuine self-runner but you could learn a lot in the process of trying.
magpwr
hi everyone,
I have attached a simplified one I/C version of the Sergey's inspired interrupter circuit.Circuit is  considered mine now. :)
Output of R9 to be connected to inverted mosfet driver.Input signal  to be connected to PWM generator output via resistor instead of function generator.
All TC4xxx Mosfet driver I/C are useless for any frequency which is higher than 150khz.
Only inverted IXYS Mosfet driver is suited for gate drive above 15volts max 24volts.
The reason why i created a HV capable PWM circuit so that i will know the L/C resonance which can applied for the center frequency of 4046 PLL.
In other words we can't run away from PWM circuit during early testing stage before going into pll.
But like said i don't want to follow L/C resonance.I already did testing using Oleg PLL circuit on breadboard and it work excellent.
If i want to run PLL at 2x the frequency of the L/C resonance which means i need to divide the frequency by 2 between pin 3/4.Easy way via 4017 configured as div by 2.
I just realize my last mistake which the assembled Oleg pll was configured to lock onto 16.5khz to 37khz.
But my L/C resonance was at 14.4khz.But i wanted pll to produce x2 resonance frequency(28.8khz) for the kacher effect as was noted in the PWM circuit.
Good thing i did not disassemble the Oleg pll circuit from the mini breadboard. :)
I think our wiring to kapanadze coil is messed up.Maybe we get something from Sergey way of connecting to kapanadze coil.
Ruslan is B.S giving lame excuses to take down his useless lame videos.
But why Akula or Dragon did not bother removing their video as well.Think about it.
Tomtech29
hello you described Pll "Oleg" which one- did you start?
You throw some scheme?
"But like said i don't want to follow L/C resonance.I already did testing using Oleg PLL circuit on breadboard and it work excellent."
I got this chip SN74SL12N and I try to piece together according to the scheme Akula no unless you have another solution?
I do not know what kind of transistor ?
magpwr
Quote from: Tomtech29 on February 09, 2016, 10:49:35 AM
Dear Tomtech29,
The attached Akula circuit was discussed few years ago.
The circuit is incomplete if you notice carefully there is a sync "P" input" which means Akula only release 1/2 the circuit to the public to ponder.
